Hello, I’m trying to package a go project, and I know next-to-nothing about go. I’m not sure if this is a go package or a go module. I’ve made a start on it and have included the files I’m using below. This project is for downloading models from hugging face and is on github here: GitHub - bodaay/HuggingFaceModelDownloader: Simple go utility to download HuggingFace Models and Datasets
The error I get when doing nix build .
is as follows. It seems to be unable to find a package ‘hfdownloader’, which I believe is part of the same repo. I’ve tried messing with the goPackagePath
, but I got stuck. Any tips appreciated!
error: builder for '/nix/store/4vbx8b88j9vm524az678240yzl0khp1c-HuggingFaceModelDownloader.drv' failed with exit code 1;
last 10 log lines:
> unpacking source archive /nix/store/cw1r1n8jb6wqqw975xrm2x958drh1f97-source
> unpacking source archive /nix/store/7w0j26wkzxhbiigqf6a0yzf8ypd3svz4-source
> building
> Building subPackage github.com/booday/HuggingFaceModelDownloader/hfdownloader
> go/src/github.com/booday/HuggingFaceModelDownloader/hfdownloader/main.go:15:2: cannot find package "github.com/bodaay/HuggingFaceModelDownloader/hfdownloader" in any of:
> /nix/store/y7abhs9glxfcg7lgcdc8i4ml5wg5ly92-go-1.21.4/share/go/src/github.com/bodaay/HuggingFaceModelDownloader/hfdownloader (from $GOROOT)
> /build/go/src/github.com/bodaay/HuggingFaceModelDownloader/hfdownloader (from $GOPATH)
For full logs, run 'nix log /nix/store/4vbx8b88j9vm524az678240yzl0khp1c-HuggingFaceModelDownloader.drv'.
– flake.nix
nixpkgs.url = "github:nixos/nixpkgs/23.11";
system = flake-utils.lib.system.x86_64-linux;
hfdownloader = pkgs.callPackage ./hfdownloader.nix { };
in { packages.${system}.default = hfdownloader; };
– hfdownloader.nix
{ fetchFromGitHub, buildGoPackage }:
buildGoPackage {
name = "HuggingFaceModelDownloader";
src = fetchFromGitHub {
owner = "bodaay";
repo = "HuggingFaceModelDownloader";
sha256 = "sha256-cDrFQTo9E112UFtam40kQ+lxPStSg4Edx1fjK2WyWHw=";
rev = "2f38356a6d6ce9c7731eb48bee35d795a4f1f67c";
goPackagePath = "github.com/booday/HuggingFaceModelDownloader/hfdownloader";
goDeps = ./deps.nix;
– deps.nix
goPackagePath = "github.com/spf13/cobra";
fetch = {
type = "FromGitHub";
owner = "spf13";
repo = "cobra";
rev = "v1.7.0";
sha256 = "sha256-oAE+fEaRfZPE541IPWE0GMeBBYgH2DMhtZNxzp7DFlY=";
goPackagePath = "github.com/joho/godotenv";
fetch = {
owner = "joho";
repo = "godotenv";
rev = "v1.5.1";
sha256 = "sha256-kA0osKfsc6Kp+nuGTRJyXZZlJt1D/kuEazKMWYCWcQ8=";
goPackagePath = "github.com/fatih/color";
fetch = {
owner = "fatih";
repo = "color";
rev = "v1.16.0";
sha256 = "sha256-6sX3ZvuVi8/3DAU1+8zN9IUpUdtT2JqwxSGldXmywzw=";
goPackagePath = "github.com/inconshreveable/mousetrap";
fetch = {
owner = "inconshreveable";
repo = "mousetrap";
rev = "v1.1.0";
goPackagePath = "github.com/mattn/go-colorable";
fetch = {
owner = "mattn";
repo = "go-colorable";
rev = "v0.1.13";
goPackagePath = "github.com/mattn/go-isatty";
fetch = {
owner = "mattn";
repo = "go-isatty";
rev = "v0.0.20";
goPackagePath = "github.com/spf13/pflag";
fetch = {
owner = "spf13";
repo = "pflag";
rev = "v1.0.5";
sha256 = "sha256-YTRLqLRZJHBh2m1dA99/EepY3DAi/rks1feB9ixT9T4=";
