I’m trying to package Rover, a CLI written in Rust. I’m fairly experienced with Nix, but not with Rust, and I’ve run into a build failure that I don’t know how to address.
My initial default.nix file:
pkgs = import (builtins.fetchTarball {
url = "https://github.com/NixOS/nixpkgs/archive/0ecf7d414811f831060cf55707c374d54fbb1dec.tar.gz";
sha256 = "00xbm9lrivsj2w1jks2cnk5brbg5kvxjfj23kq0qyr8nvh57wln9";
with pkgs; rustPlatform.buildRustPackage rec {
pname = "rover";
version = "v0.4.1";
src = fetchFromGitHub {
owner = "apollographql";
repo = pname;
rev = version;
sha256 = "1i0l3h8ylqpzlsvk2l9krjhwvqr2d62fvx5kdxdyznm8mgp14p3g";
cargoSha256 = "1j8r5pknh5law1c1gwh5xbaqw2xjwql3sk29qdaqwaih6i18hq62";
meta = with lib; {
description = "A tool for working with the Apollo GraphQL Registry";
homepage = "https://github.com/apollographql/rover";
license = licenses.mit;
maintainers = [ maintainers.ivanbrennan ];
When I run nix-build, the unpack, patch, and configure phases go smoothly, but the build phase eventually fails with:
error: failed to run custom build command for `rusty_v8 v0.22.3`
Here are the (abbreviated) logs from the build phase:
@nix { "action": "setPhase", "phase": "buildPhase" }
building
Executing cargoBuildHook
++ env CC_x86_64-unknown-linux-gnu=/nix/store/68kch2wwp5hnbfvmvzxbb33v8smw6ixk-gcc-wrapper-10.3.0/bin/cc CXX_x86_64-unknown-linux-gnu=/nix/store/68kch2wwp5hnbfvmvzxbb33v8smw6ixk-gcc-wrapper-10.3.0/bin/c++ CC_x86_64-unknown-linux-gnu=/nix/store/68kch2wwp5hnbfvmvzxbb33v8smw6ixk-gcc-wrapper-10.3.0/bin/cc CXX_x86_64-unknown-linux-gnu=/nix/store/68kch2wwp5hnbfvmvzxbb33v8smw6ixk-gcc-wrapper-10.3.0/bin/c++ cargo build -j 8 --target x86_64-unknown-linux-gnu --frozen --release
Compiling libc v0.2.107
Compiling autocfg v1.0.1
Compiling ansi_colours v1.0.4
Caused by:
process didn't exit successfully: `/build/source/target/release/build/rusty_v8-1c2a1954c28f190d/build-script-build` (exit status: 101)
--- stdout
cargo:rerun-if-changed=src/binding.cc
download lockfile: "/build/source/target/x86_64-unknown-linux-gnu/release/build/lib_download.fslock"
static lib URL: https://github.com/denoland/rusty_v8/releases/download/v0.22.3/librusty_v8_release_x86_64-unknown-linux-gnu.a
cargo:rustc-link-search=/build/source/target/x86_64-unknown-linux-gnu/release/gn_out/obj
Downloading https://github.com/denoland/rusty_v8/releases/download/v0.22.3/librusty_v8_release_x86_64-unknown-linux-gnu.a
Python downloader failed, trying with curl.
--- stderr
thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: Os { code: 2, kind: NotFound, message: "No such file or directory" }', /build/rover-v0.4.1-vendor.tar.gz/rusty_v8/build.rs:281:10
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
warning: build failed, waiting for other jobs to finish...
error: build failed
The error’s immediate cause is an attempt to run curl (which I haven’t provided in the build inputs), in part of the build for rusty_v8, specifically here. This stems from an attempt to download static lib binaries rather than building V8 from source.
I found a Nix derivation for a different Rust package (Deno) that uses a RUSTY_V8_ARCHIVE environment variable to tell the rusty build script to use a Nix-provided package of the librusty_v8 library (as documented here), so I tried to do the same in my derivation, ending up with the following default.nix file:
arch = pkgs.rust.toRustTarget pkgs.stdenv.hostPlatform;
fetch_librusty_v8 = args: pkgs.fetchurl {
name = "librusty_v8-${args.version}";
url = "https://github.com/denoland/rusty_v8/releases/download/v${args.version}/librusty_v8_release_${arch}.a";
sha256 = args.sha256;
meta = { inherit (args) version; };
librusty_v8 = fetch_librusty_v8 {
version = "0.22.3";
sha256 = "07qavwvppywyn1a3v2ladj26gpwaj979xnmfkxjkisz6wi95yba5";
pname = "rover";
version = "v0.4.1";
repo = pname;
rev = version;
# The v8 package will try to download a `librusty_v8.a` release at build time to our read-only filesystem
# To avoid this we pre-download the file and export it via RUSTY_V8_ARCHIVE
RUSTY_V8_ARCHIVE = librusty_v8;
meta = with lib; {
platforms = [ "x86_64-linux" ];
But this didn’t make any difference (it’s still attempting to download v8).
It looks like the name of the appropriate environment variable may have changed, and was RUSTY_V8_MIRROR in rusty_v8 version 0.22.3, so I renamed my env var accordingly, but it made no difference.
Any pointers toward solving this problem (or finding a different approach)?
