I was trying to apply this patch to the current nixos kernel inspired by this post .
Patching, building and loading the module works perfectly, but I don’t see that support for Broadcom is being loaded when the hci_uart module is being loaded, so I suspect that the Kernel flags are not what I expect. Is there a way to explicitly set kernel flags using the approach that I took to build the driver?
configuration.nix
hci_uart-kernel-module = pkgs.callPackage ./hci_uart.nix { inherit (config.boot.kernelPackages) kernel; };
patched = hci_uart-kernel-module.overrideAttrs (prev: {
patches = [ ./hci_bcm.patch ./Makefile.patch ];
boot.extraModulePackages = [
(lib.hiPrio patched)
hci_uart.nix
{ stdenv, lib, kernel }:
modPath = "drivers/bluetooth";
modDestDir = "$out/lib/modules/${kernel.modDirVersion}/kernel/${modPath}";
in stdenv.mkDerivation rec {
name = "hci_uart-${kernel.version}";
inherit (kernel) src version;
postPatch = ''
cd ${modPath}
nativeBuildInputs = kernel.moduleBuildDependencies;
makeFlags = kernel.makeFlags ++ [
"-C ${kernel.dev}/lib/modules/${kernel.modDirVersion}/build"
"M=$(PWD)"
"modules"
enableParallelBuilding = true;
installPhase = ''
runHook preInstall
mkdir -p ${modDestDir}
find . -name '*.ko' -exec cp --parents '{}' ${modDestDir} \;
find ${modDestDir} -name '*.ko' -exec xz -f '{}' \;
runHook postInstall
meta = with lib; {
description = "MacBook bluetooth drivers";
inherit (kernel.meta) license platforms;
PS: I tested the same patch a few days ago on Arch, so the driver should work for my Macbook.
Looking at the build logs i see that hci_bcm which is the file I am patching is not being built.
patching file drivers/bluetooth/Makefile
Running phase: configurePhase
Running phase: buildPhase
build flags: -j4 SHELL=/nix/store/7dpxg7ki7g8ynkdwcqf493p2x8divb4i-bash-5.2-p15/bin/bash O=\$\(buildRoot\) CC=/nix/store/vylmp73qymnv4siaqn1kl2hghj07hrj8-gcc-wrapper-12.3.0/bin/cc HOSTCC=/nix/store/vylmp73qymnv4siaqn1kl2hghj07hrj8-gcc-wrapper-12.3.0/bin/cc HOSTLD=/nix/store/qcg3rpl1l103zb1xfsw40wm9j5hzrp7y-binutils-wrapper-2.40/bin/ld ARCH=x86_64 -C /nix/store/kpwm0vhi68njzhcqfbym2jj4jp9h740x-linux-6.1.76-dev/lib/modules/6.1.76/build M=\$\(PWD\) modules
CC [M] /build/linux-6.1.76/drivers/bluetooth/hci_ldisc.o
CC [M] /build/linux-6.1.76/drivers/bluetooth/hci_serdev.o
CC [M] /build/linux-6.1.76/drivers/bluetooth/hci_h4.o
CC [M] /build/linux-6.1.76/drivers/bluetooth/hci_bcsp.o
CC [M] /build/linux-6.1.76/drivers/bluetooth/hci_ll.o
CC [M] /build/linux-6.1.76/drivers/bluetooth/hci_qca.o
LD [M] /build/linux-6.1.76/drivers/bluetooth/hci_uart.o
MODPOST /build/linux-6.1.76/drivers/bluetooth/Module.symvers
CC [M] /build/linux-6.1.76/drivers/bluetooth/hci_uart.mod.o
LD [M] /build/linux-6.1.76/drivers/bluetooth/hci_uart.ko
BTF [M] /build/linux-6.1.76/drivers/bluetooth/hci_uart.ko
Skipping BTF generation for /build/linux-6.1.76/drivers/bluetooth/hci_uart.ko due to unavailability of vmlinux
Running phase: installPhase
Running phase: fixupPhase
My guess is that I need a way to define CONFIG_BT_HCIUART_BCM y before building the kernel module. Any idea how I can achieve this?
When I add the flag as:
boot.kernelPatches = [ {
name = "bcm-config";
patch = null;
extraConfig = ''
I get the error:
GOT: make: Leaving directory '/build/linux-6.1.76'
error: unused option: CONFIG_BT_HCIUART_BCM
… so that’s probably not the way
If I pass the config like:
patch = null;
extraConfig = ''
BT_HCIUART_BCM y
it starts compiling the whole kernel, but that’s quite expensive in terms of resources for a fanless MacBook, so it would be great if someone could point out to me how to pass it only for small module compilation.
jottr
March 9, 2024, 2:14pm
6
@florin-pop were you ever able to figure this out?
No, every time there’s a kernel update it compiles the entire kernel, it’s quite annoying as it takes 2-3hrs, but bluetooth works. I guess the default kernel doesn’t have broadcom driver support and maybe that’s why just compiling the driver didn’t work.
