Help setting up a BTA! modding environment
getting this error:
Unpacked JDK archive does not contain a Java home: /home/gobbe/.gradle/.tmp/jdks/OpenJDK21U-jdk_x64_linux_hotspot_21-Eclipse-Temurin-2111441753919758025703.tmp
Installing Java through Home Manager, but unsure if JAVA_HOME is properly set
programs.java = {
    package = pkgs.jdk17;
# it says it sets home.sessionVariables.JAVA_HOME = "${cfg.package.home}";
# but unsure if IDEA/gradle finds this $JAVA_HOME
installing IDEA with:
export NIXPKGS_ALLOW_UNFREE=1
nix-shell -p jetbrains.idea
tried using the BTA! mod template on codeberg ( gobbe/bta-test: det rullar nu? - Codeberg.org ) and github ( GitHub - Turnip-Labs/bta-example-mod: Fabric example mod for BTA · GitHub ), talked to the devs and they say they’ve never seen an error like this before. Both these examples work on a windows machine. Both produce the same error on NixOS
In other words, I opened IDEA, cloned either repo A or B. Waited for imports, then restarted IDEA. Error.
wondering what dependancies I should tweak or env-vars I should add to let gradle see java home
*could also be that gradle atm is doing auto-install of java, and that java doesn’t have a proper nixos $JAVA_HOME - if so I wonder how to set gradle up to use a current install of java.
Either way have struggled with this awhile and heard others also have had this issue so wondering if there are any solutions :slight_smile:
Not sure if I will be able to help, but have you tried echo $JAVA_HOME ?
And what happens on a hello-world java project ?
Also it’s not very clear how you reach this error, and were it comes from
Could you give the steps in chronological order ?
And “BTA!” is the mod “Better Than Adventure” for minecraft, right ?
Yes, sorry for being unclear with BTA! I am reffering to Better than adventure :³
running echo $JAVA_HOME returns nothing atm /:
At the moment the steps I took to get this error where
  1. Install Java (17) through home manager
  2. Install jetbrains.idea with a nix-shell
  3. Clone the example repo
  4. Open it with IDEA and let it load
  5. Restart IDEA
Then error
So:
  1. Where is the error printed ?
  2. It works perfectly fine the first time ?
If I were you I would now look into what JAVA_HOME is, and what home.sessionVariables.JAVA_HOME (if you don’t already)
As I personnally do not, I can’t help you on this front
Oh and also the original error does not point at the nix store, could you check if it’s a symlink to it ?
When I wanted to do some MC dev work, I used a devshell, that worked.
There might be some things you don’t need in there, so some experimentation might be required on your part.
The main takeaway is that you can tell gradle where the JDKs it needs are at with these lines in your gradle.properties
org.gradle.java.installations.auto-download=false
org.gradle.java.installations.fromEnv=JDK8,JDK17,JDK21,JDK25
which is documented here.
The reason I specifically have the Zulu JDK in there is because I was working with GTNH RFB, which aggressively wanted to download its own jdk and was only content with Zulu (I did not and still do not know enough to disable foojay-resolver or whatever it is called).
See my flake attached, maybe it helps you. I used direnv and launched intellij from the shell, but entering the shell with nix shell or using the direnv intellij plugin might also work, YMMV.
Nix flake
  description = "mc intellij flake";
    nixpkgs.url = "https://channels.nixos.org/nixos-unstable/nixexprs.tar.zst";
  outputs =
    { self, nixpkgs, ... }@inputs:
      system = "x86_64-linux";
      devShells.${system}.default = pkgs.mkShell {
        packages = with pkgs; [
          zulu25
          zulu21
          zulu17
          zulu8
          gradle_9
          jetbrains.idea-oss
          xrandr
        shellHook = "echo 'happy hacking'";
        JDK8 = "${pkgs.zulu8}";
        JDK17 = "${pkgs.zulu17}";
        JDK25 = "${pkgs.zulu25}";
        JDK21 = "${pkgs.zulu21}";
        JDKJB = "${pkgs.jetbrains.jdk-no-jcef}";
        LD_LIBRARY_PATH = pkgs.lib.makeLibraryPath (
          with pkgs;
            glfw3-minecraft
            libGL
            libX11
            libXcursor
            libXext
            libXrandr
            libXxf86vm
            libjack2
            libpulseaudio
            libusb1
            openal
            xrandr
Oh no sorry. I am restarting IDEA here because the tutorial I was referencing (from the BTA devs) pointed out that restarting was required to properly load libraries within the project.
The error itself shows up inside IDEA. Boiled it down to just being an issue with gradle linking that is IDEA specific (IDEA tries to install gradle stuffs but because nixos has a different linker thingy it cannot).
Holy shit thanksss :³
IDEA-oss has a bunch of security vulns so I had to go round abit butttt, ended up here:
$ export NIXPKGS_ALLOW_INSECURE=1
$ nix develop --impure
Commented out the line with zulu8 & JDK8 as that seemed to have been dropped (or relied on deps that have been dropped, something about gtk2).
Building IDEA-oss resulted in a build error :] But it seemed to be correct despite that. Might do some testing later but gonna leave it here for now
