I’m running Hyprland wayland compositor on a flake-based NixOS setup. I have a mostly working hyprland.conf (I’m just using the home.file method in home-manager to apply hyprland.conf, which is to say I’m not declaring hyprland settings using nix syntax):
home.file."${config.xdg.configHome}/hypr" = {
source = ../dotfiles/hypr;
recursive = true;
The output of hyprctl devices
on my system outputs the following:
mice:
Mouse at 1cbd000:
synps/2-synaptics-touchpad
default speed: 0.00000
Mouse at 1cbddc0:
tpps/2-alps-trackpoint
Mouse at 1a64240:
razer-proclickm-mouse
Mouse at 17fa9c0:
razer-proclickm-keyboard-1
Mouse at 19fff00:
razer-proclickm-1
The device section of my hyprland.conf, following the instructions on the wiki - Keywords – Hyprland Wiki - looks like this:
device {
name = razer-proclickm-1
sensitivity = -0.5
This works exactly as it should on my Arch system running hyprland Unfortunately, this has no effect on my NixOS system and I’ve been struggling to figure out why.
For what its worth, I’ve also tried with the other two razer mouse names (razer-proclickm-keyboard-1
and razer-proclickm-mouse
), both individually and in combination with razer-proclickm-1
in the device {}
block to no effect. The touchpad and trackpoint items have no effect either (not even on the actual trackpad and trackpoint sensitivity of my laptop).
Also for reference, although I’m not sure it should have any effect on what I’m trying to do specifically, here is the input section of my hyprland.conf:
input {
kb_layout = us
repeat_delay = 300
repeat_rate = 50
follow_mouse = 1
sensitivity = 0 # -1.0 - 1.0, 0 means no modification.
touchpad {
natural_scroll = true
disable_while_typing = true
Changing the sensitivity setting in either device
and/or input
sections has no effect. Can anyone help me troubleshoot this?
