I was looking into how MangoHud is packaged and noticed how it has a dependency on its 32-bit (i686) package. I am having a hard time understanding what is happening here.
mangohud
itself is declared here for all packages:
mangohud = callPackage ../tools/graphics/mangohud {
libXNVCtrl = linuxPackages.nvidia_x11.settings.libXNVCtrl;
mangohud32 = pkgsi686Linux.mangohud;
This makes sense. I know what callPackage
is for and meant to do. Here overrides are being declared for those two attributes, since callPackage
won’t be able to find them in the function args intersection for the package expression itself here. Here is also where a dependency on the i686
version of the package is introduced.
This is then used in the final 64-bit package to add some 32-bit support workarounds, such as here:
# Support 32bit Vulkan applications by linking in 32bit Vulkan layers
# This is needed for the same reason the 32bit preload workaround is needed.
postInstall = lib.optionalString lowerBitnessSupport ''
ln -s ${mangohud32}/share/vulkan/implicit_layer.d/MangoHud.x86.json \
"$out/share/vulkan/implicit_layer.d"
Since lowerBitnessSupport
sorts itself out to the correct value for the architecture being built for, there shouldn’t be issues here. It will be false
for the i686
version and true
for the 64-bit version. As such mangohud32
won’t be evaluated for the 32-bit build and won’t create an infinite recursion scenario:
lowerBitnessSupport ? stdenv.hostPlatform.isx86_64, # Support 32 bit on 64bit
Even if you were to callPackage
the package expression without passing a mangohud32
value, it would error out since the mangohud32
parameter isn’t optional and callPackage
seemingly wouldn’t pass a placeholder value to satisfy this. That is unless there are gaps in my understanding. So something has to be passed for the 32-bit build, but I’m not sure what or how this all comes together.
pkgsi686Linux
is evaluated here seemingly and then passed through here in all-packages.nix
through the with
expression at the top, but I am still not tracking.
If the 64-bit derivation depends on the 32-bit derivation that uses the same derivation expression, which itself depends on mangohud32
itself, how does this all work? Can someone provide insight into “the flow” of evaluation to make this all work and not be infinitely recursive?
Thanks.
