Help wanted for NixOS config with Flakes and home-manager
Here’s my configuration.
Every time I add a new file to my configuration, I get this error when rebuilding the configuration under a configured system:
command: cd ~/.nix && sudo nixos-rebuild switch --flake '.#sakura'
result:
error:
         at /nix/store/3j9garb3574mxikwbi6zn594j8mjd19s-source/lib/attrsets.nix:784:11:
          783|         || pred here (elemAt values 1) (head values) then
          784|           head values
          785|         else
         at /nix/store/3j9garb3574mxikwbi6zn594j8mjd19s-source/lib/modules.nix:768:9:
          767|     in warnDeprecation opt //
          768|       { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
          769|         inherit (res.defsFinal') highestPrio;
       error: getting status of '/nix/store/icnm9r8vjdm0lir9c5ljib7zrlm338gp-source/modules/programs/lf.nix': No such file or directory
This time is I added configuration of lf.
Also, I can build it under a not configured system.
I’m rather new to Nix, so forgive me.
However, I do not see a file named “lf.nix” in your repo https://github.com/vollowx/.nix/tree/main/modules/programs
If you’re adding files while testing on an existing system, you first need to add (stage) the files in git using a command like git add . (or git add <filename>), otherwise, they won’t be visible to the flake. This also applies when moving and renaming files/folders. Having done that, the flake should then be able to “see” them.
Note: It is not required to commit or push the changes, for the sole purpose of testing them in your local flake.
Thanks a lot! It’s solved now!
I used to do Git commits by git commit -a -m 'commit messages...' since I found this shortcut feature but I didn’t know it won’t include new files :thinking:
