I have the following file that set some options only for linux as darwin doest have the attributes:
lib,
config,
pkgs,
myvars,
cfg = config.modules.matrix;
inherit (pkgs.stdenv) isDarwin;
options.modules.matrix = {
enable = lib.mkEnableOption "enable matrix module";
pkg = lib.mkPackageOption pkgs "weechat" { };
config = lib.mkIf cfg.enable (
lib.mkMerge [
cfg.pkg
pkgs.element-desktop
(lib.mkIf (!isDarwin) {
services.weechat.enable = lib.mkDefault true;
programs.screen.screenrc = ''
multiuser on
acladd ${myvars.username}
term screen-256color
But even with the if blocks the i still get the error programs.screen
does not exist when i try to build on darwin. what do i do?
