Say I have the nix expression for the C++ linear algebra library, petsc locally on my machine in a directory called ./petsc
. This contains the files in the link above, namely default.nix
and filter_mpi_warnings.patch
Say I am locally working on debugging this package. How do I run nix-build
locally to test the build?
I’ve tried nix-build
and nix-build -A petsc
but all the required arguments like lib, stdenv, fetchurl, darwin, gfortran , python3, ...
are missing. I get the error:
error: cannot evaluate a function that has an argument without a value ('fetchurl')
Nix attempted to evaluate a function as a top level expression; in
this case it must have its arguments supplied either by default
values, or passed explicitly with '--arg' or '--argstr'. See
https://nixos.org/manual/nix/stable/language/constructs.html#functions.
at /home/lj/Desktop/petsc/default.nix:3:3:
2| , stdenv
3| , fetchurl
4| , darwin
I’ve tried making a file called build.nix
that contains the following"
nixpkgs = fetchTarball "https://github.com/NixOS/nixpkgs/tarball/nixpkgs-unstable";
pkgs = import nixpkgs { config = {}; overlays = []; };
petsc = pkgs.callPackage ./default.nix { };
and running nix-build ./build.nix petsc
but this fails as well.
I’m sorry, this seems like it should be so basic. I can make little hello world or simple programs into nix packages no problem, but the moment I have a bunch of build inputs like this, I have no idea how to build it locally.
Edit: turns out my problem had to do with buildPythonPackage and not a failure to pass input arguments to the package.
