I am creating a custom derivation that downloads an artifact (this artifact is not statically linked).
name = "simple";
src = ./.;
packages = {
} // (if system == "x86_64-linux" then {
spanner-emulator =
version = "1.5.2";
inherit (pkgs) stdenv lib;
stdenv.mkDerivation
name = "spanner-emulator";
src = pkgs.fetchurl {
url =
"https://storage.googleapis.com/cloud-spanner-emulator/releases/${version}/cloud-spanner-emulator_linux_amd64-${version}.tar.gz";
sha256 = "e02e53776f36865dd581234c0c21a54add77d88fb956023aa47f99d96c0af788";
buildInputs = [ pkgs.stdenv.cc.cc.lib ];
nativeBuildInputs = [ pkgs.stdenv.cc.cc.lib ];
phases = [ "unpackPhase" "installPhase" ];
unpackPhase = ''
mkdir -p $out/bin
tar -xzf $src -C $out/bin
# this phase is not necessary, but it's here to show how to install
installPhase = ''
meta = with nixpkgs.lib; {
homepage = "https://github.com/GoogleCloudPlatform/cloud-spanner-emulator";
description =
"Cloud Spanner Emulator is a local emulator for the Google Cloud Spanner database service.";
platforms = platforms.linux;
} else { });
defaultPackage = self.packages.spanner-emulator;
How do I make a devShell from this with this default package in the path?
I also tried using devbox tool to create, but I get this error
/nix/store/pz5gz7b6hnrkyilakr4sbzclmhrlv1cf-spanner-emulator/bin/emulator_main: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by /home/user/Projects/spanner-emulator/.devbox/nix/profile/default/lib/libstdc++.so.6)
Your’re very close! I think you’re missing libstdc++5 in your build inputs, the c++ standard library might not be part of the stdenv.cc.lib. See nixpkgs search
name = "simple";
src = ./.;
rec {
packages = { } // (if system == "x86_64-linux" then {
spanner-emulator =
version = "1.5.2";
stdenv.mkDerivation rec
url =
sourceRoot = ".";
unpackPhase = ''
mkdir -p $out/bin
buildPhase = ":";
libPath = with pkgs; lib.makeLibraryPath [
pkgs.stdenv.cc.cc.lib # libstdc++.so.6
postFixUp = ''
patchelf \
--set-interpreter "$(cat $NIX_CC/nix-support/dynamic-linker)" \
--set-rpath "${libPath}" \
$out/bin/emulator_main
description =
} else { });
devShells = { } // (if system == "x86_64-linux" then {
default = pkgs.mkShell rec {
LD_LIBRARY_PATH = "${libPath}";
buildInputs = [
self.packages.${system}.spanner-emulator
} else { });
I used postFixUp command, but now I get different error
emulator_main: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by /nix/store/7ls5xhx6kqpjgpg67kdd4pmbkhna4b6c-gcc-12.2.0-lib/lib/libstdc++.so.6)
emulator_main: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.32' not found (required by /nix/store/7ls5xhx6kqpjgpg67kdd4pmbkhna4b6c-gcc-12.2.0-lib/lib/libstdc++.so.6)
emulator_main: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.36' not found (required by /nix/store/7ls5xhx6kqpjgpg67kdd4pmbkhna4b6c-gcc-12.2.0-lib/lib/libstdc++.so.6)
emulator_main: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /nix/store/7ls5xhx6kqpjgpg67kdd4pmbkhna4b6c-gcc-12.2.0-lib/lib/libstdc++.so.6)
emulator_main: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.35' not found (required by /nix/store/7ls5xhx6kqpjgpg67kdd4pmbkhna4b6c-gcc-12.2.0-lib/lib/libgcc_s.so.1)
emulator_main: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /nix/store/7ls5xhx6kqpjgpg67kdd4pmbkhna4b6c-gcc-12.2.0-lib/lib/libgcc_s.so.1)
Hmm that /lib/x86_64-linux-gnu/libc.so.6 is not good, that should be /nix/store/x33pcmpsiimxhip52mwxbb5y77dhmb21-glibc-2.37-8/lib/libc.so.6 like it was before.
The error message basically means that the glibc of your distro is not new enough to run the binary, which is not surprising.
Can you check what ldd returns for your new binary?
You could also try running the newly patched binary with LD_PRELOAD:
Please use the autoPatchelfHook or manual alternatives to properly patch the prebuild binary or even better, build it from source if the sources are available.
