Hey guys, I’m trying to import the NUR Emacs-init Home-manager module but I keep getting infinite recursion issues
I imported NUR as an overlay (I’m currently using some NUR packages specifically for downloading Firefox extensions) but this doesn’t seem to be working with NUR modules. Any advice to properly setup the module?
Flake.nix:
Overlay:
Emacs.nix
{ config, lib, pkgs, nur, ... }:
pack = if (config.variables.desktop.displayManager == "wayland") then
pkgs.emacs29-pgtk
else
pkgs.emacs29;
imports = [ nur.repos.rycee.hmModules.emacs-init ];
services.emacs = {
defaultEditor = true;
startWithUserSession = "graphical";
client = {
#arguments = [ ];
programs = {
pyenv.enable = true;
emacs = {
package = pack;
extraPackages = epkgs: with epkgs; [ tramp pdf-tools vterm ];
The error
$ nix-shell --run "home-manager switch --flake $FLAKE --show-trace"
error:
… from call site
at /nix/store/c1kciy1zip6av31s6bi0bn3l6lz8j4wj-source/modules/default.nix:44:18:
43| withExtraAttrs = rawModule:
44| let module = moduleChecks rawModule;
45| in {
… while calling 'moduleChecks'
at /nix/store/c1kciy1zip6av31s6bi0bn3l6lz8j4wj-source/modules/default.nix:31:18:
30|
31| moduleChecks = raw:
32| showWarnings (let
… from call site
at /nix/store/c1kciy1zip6av31s6bi0bn3l6lz8j4wj-source/modules/default.nix:32:5:
33| failed = collectFailed raw.config;
… while calling 'showWarnings'
at /nix/store/c1kciy1zip6av31s6bi0bn3l6lz8j4wj-source/modules/default.nix:15:18:
14|
15| showWarnings = res:
16| let f = w: x: builtins.trace "warning: ${w}" x;
… from call site
at /nix/store/c1kciy1zip6av31s6bi0bn3l6lz8j4wj-source/modules/default.nix:17:8:
17| in fold f res res.config.warnings;
18|
… while calling 'foldr'
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/lists.nix:121:20:
120| */
121| foldr = op: nul: list:
122| let
… from call site
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/lists.nix:128:8:
127| else op (elemAt list n) (fold' (n + 1));
128| in fold' 0;
129|
… while calling 'fold''
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/lists.nix:124:15:
123| len = length list;
124| fold' = n:
125| if n == len
… from call site
at /nix/store/c1kciy1zip6av31s6bi0bn3l6lz8j4wj-source/modules/default.nix:33:16:
34| failedStr = concatStringsSep "\n" (map (x: "- ${x}") failed);
… while calling 'collectFailed'
at /nix/store/c1kciy1zip6av31s6bi0bn3l6lz8j4wj-source/modules/default.nix:12:19:
11|
12| collectFailed = cfg:
13| map (x: x.message) (filter (x: !x.assertion) cfg.assertions);
… from call site
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:242:28:
241| # For definitions that have an associated option
242| declaredConfig = mapAttrsRecursiveCond (v: ! isOption v) (_: v: v.value) options;
243|
… while calling 'mapAttrsRecursiveCond'
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/attrsets.nix:1167:5:
1166| f:
1167| set:
1168| let
… from call site
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:234:33:
233| ({ inherit lib options config specialArgs; } // specialArgs);
234| in mergeModules prefix (reverseList collected);
235|
… while calling 'reverseList'
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/lists.nix:1068:17:
1067| */
1068| reverseList = xs:
1069| let l = length xs; in genList (n: elemAt xs (l - n - 1)) l;
… from call site
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:229:25:
228| merged =
229| let collected = collectModules
230| class
… while calling anonymous lambda
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:445:37:
444|
445| in modulesPath: initialModules: args:
446| filterModules modulesPath (collectStructuredModules unknownModule "" initialModules args);
… from call site
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:446:7:
447|
… while calling 'filterModules'
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:413:36:
412| # modules recursively. It returns the final list of unique-by-key modules
413| filterModules = modulesPath: { disabled, modules }:
414| let
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:439:31:
438| disabledKeys = concatMap ({ file, disabled }: map (moduleKey file) disabled) disabled;
439| keyFilter = filter (attrs: ! elem attrs.key disabledKeys);
440| in map (attrs: attrs.module) (builtins.genericClosure {
… from call site
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:400:22:
399| let
400| module = checkModule (loadModule args parentFile "${parentKey}:anon-${toString n}" x);
401| collectedImports = collectStructuredModules module._file module.key module.imports args;
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:365:11:
364| else
365| m: m;
366|
… from call site
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:400:35:
399| let
… while calling 'loadModule'
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:336:53:
335| # Like unifyModuleSyntax, but also imports paths and calls functions if necessary
336| loadModule = args: fallbackFile: fallbackKey: m:
337| if isFunction m then
… from call site
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:337:12:
338| unifyModuleSyntax fallbackFile fallbackKey (applyModuleArgs fallbackKey m args)
… while calling 'isFunction'
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/trivial.nix:929:16:
928| */
929| isFunction = f: builtins.isFunction f ||
930| (f ? __functor && isFunction (f.__functor f));
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:506:44:
505| context = name: ''while evaluating the module argument `${name}' in "${key}":'';
506| extraArgs = builtins.mapAttrs (name: _:
507| builtins.addErrorContext (context name)
… while evaluating the module argument `nur' in "/nix/store/dsa1bc6gzhdwkw16sgaf0chz03m1s681-source/home/novaviper/features/emacs":
error: infinite recursion encountered
at /nix/store/panhvrac6ra4wpj9hrg19v4gn189hrqw-source/lib/modules.nix:508:28:
508| (args.${name} or config._module.args.${name})
509| ) (lib.functionArgs f);
