Looking for some help in order to finish [WIP] ZLUDA: init at 3 by errnoh · Pull Request #288644 · NixOS/nixpkgs · GitHub
This packages GitHub - vosen/ZLUDA: CUDA on AMD GPUs, which is rather complex library for running CUDA applications with AMD hardware.
Before starting the PR I did manage to build the package manually (resulting in the lockfile that’s being used in the PR), but any attempt to compile it in a package just results in errors. I’ve made some progress on the package (thanks @SergeK), but there’s the nagging feel that if I could get someone familiar with Rust to take a look this would be done quite fast ![]()
Details are in the PR, but basically the furthest I’ve got so far is:
Compiling dynasmrt v1.2.3
error: failed to run custom build command for `zluda v0.0.0 (/build/source/zluda)`
Caused by:
process didn't exit successfully: `/build/source/target/release/build/zluda-80c9fbe76904c49f/build-script-build` (exit status: 101)
--- stderr
thread 'main' panicked at zluda/build.rs:4:29:
called `Result::unwrap()` on an `Err` value: could not find repository from '/build/source/zluda'; class=Repository (6); code=NotFound (-3)
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
warning: build failed, waiting for other jobs to finish...
error: builder for '/nix/store/1almnpy0bpkmsa1gm3c0g2hxg3fvpivf-zluda-3.drv' failed with exit code 101;
last 10 log lines:
> Caused by:
> --- stderr
For full logs, run 'nix log /nix/store/1almnpy0bpkmsa1gm3c0g2hxg3fvpivf-zluda-3.drv'.
which seems to fail the following build.rs:
use vergen::{Config, vergen};
fn main() {
vergen(Config::default()).unwrap()
