Hello,
absolutely new to NixOS and having an issue with Samba.
I started with the Samba wiki entry, copying & pasting the server example (adapting the paths).
After setting Credential used to access SMB shares
I can connect to shared resources on other computers. So far, so good.
Issue starts when I try to share from NixOS.
Tried with Dolphin, but in the “Share” tab shows a “Samba is not installed on your system” message. I then installed kdeApplications.kdenetwork-filesharing
(is this necessary?), and the issue persists.
A few attempts that I did.
# systemctl restart samba
from the Wiki page fails. Perhaps Samba is actually not installed!, but the command # systemctl restart samba-smbd
works. Nothing changes, but I assume now that Samba is installed. And it seems to be the case.
/etc/samba/samba.conf
exists:
$ ls /etc/samba/smb.conf
/etc/samba/smb.conf
services are enabled:
$ systemctl list-unit-files | grep samba
samba-nmbd.service enabled
samba-setup.service linked
samba-smbd.service enabled
samba-winbindd.service enabled
samba.target enabled
Probably not necessary, but I tried with smbpasswd
etc.
Rebooted. Nothing. Tried something else:
$ net rpc user
Enter WORKGROUP\max's password:
max
$ net rpc share list -U max
private
public
IPC$
Last try:
$ net usershare info --long
net usershare: usershares are currently disabled
Interesting… Can be this the problem?
After searching in the Wiki, Google, etc I have no clues: how to enable usershares in NixOS (if this is the point)?
If it can help, I have a gist with the excerpt that I use,
$ nix --version
nix (Nix) 2.2.2
system.stateVersion = "19.03";
