Hi all, someone can help me to set zrepl? I’m using this with arch, Gentoo and feeebsd. I puted package and service.zrepl.enable on my configuration.nix but I didn’t understand how create its configuration file
The config file is created by its corresponding settings option.
https://search.nixos.org/options?channel=unstable&show=services.zrepl.settings&from=0&size=50&sort=relevance&type=packages&query=services.zrepl.settings
I’m using this model
but when I launch nixos-rebuild test I have a few errors, e.g. an error near jobs :
This afternoon I post correct error
There are errors:
[11:41:42] zar_marco :: nixgram ➜ ~ » sudo nixos-rebuild test
error:
… while evaluating the attribute 'config'
at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:322:9:
321| options = checked options;
322| config = checked (removeAttrs config [ "_module" ]);
323| _module = checked (config._module);
… while calling the 'seq' builtin
at /nix/var/nix/profiles/per-user/root/channels/nixos/lib/modules.nix:322:18:
error: syntax error, unexpected '='
at /etc/nixos/zrepl.nix:8:10:
7| jobs = [
8| name = "snapjob";
9| type = "snap";
building Nix...
error:
7| jobs = [
9| type = "snap";
error:
… while evaluating the attribute 'config.system.build.toplevel'
7| jobs = [
9| type = "snap";
and this is my zrepl.nix file
`[11:44:43] zar_marco :: nixgram ➜ ~ » cat /etc/nixos/zrepl.nix
{ config, pkgs, lib, … }:
services.zrepl.settings = {
jobs = [
name = “snapjob”;
type = “snap”;
filesystems: {
“rpool/root/nixos”: true,
“rpool/data/nixos-home”: true,
“rpool/data/condivise”: true,
snapshotting:
type: periodic
interval: 30m
prefix: zrepl_snapjob_
pruning:
keep:
- type: last_n
count: 20
The linked snippet seems to be no valid nix.
You could peek on my config. nix-configuration/machines/tank/configuration.nix at 6f155193b2f261e22e0ae162e2d0a9a26d900484 · Shawn8901/nix-configuration · GitHub
The nix code will be translated to yaml by the module
Thanks so much, I generated setting correctly. Now I must understand how enable systemd service
Sorry, I’ve this error that I don’t know
[17:25:32] zar_marco :: nixgram ➜ ~ » systemctl status zrepl.service
○ zrepl.service - zrepl daemon
Loaded: loaded (/etc/systemd/system/zrepl.service; enabled; preset: enabled)
Drop-In: /nix/store/p1mpzax6sjblibiv7gpi5iskkc4vl2wg-system-units/zrepl.service.d
└─overrides.conf
Active: inactive (dead) since Mon 2024-04-01 17:20:34 CEST; 5min ago
Docs: https://zrepl.github.io
Process: 4860 ExecStartPre=/nix/store/hnwbdspbqacr1b84c2q0ziss93k21mvs-zrepl-0.6.1/bin/zrepl --config /etc/zrepl/zrepl.yml configcheck (co>
IP: 0B in, 0B out
CPU: 30ms
apr 01 17:20:34 nixgram systemd[1]: zrepl.service: Scheduled restart job, restart counter is at 5.
apr 01 17:20:34 nixgram systemd[1]: zrepl.service: Start request repeated too quickly.
apr 01 17:20:34 nixgram systemd[1]: zrepl.service: Failed with result 'exit-code'.
apr 01 17:20:34 nixgram systemd[1]: Failed to start zrepl daemon.
[17:25:47] zar_marco :: nixgram ➜ ~ »
can I fixed this?
The module already enables the systems service, there should not be any need of manual intervention. Just activate the config switch switch or test, or enable it with boot and reboot.
Posting an actual error could be helpful. You now have postet “sorry I can not start, there is something wrong with config” (pre check fails)
It would be also interesting what systems override you have applied
Ok this is the error:
[18:13:49] zar_marco :: nixgram ➜ ~ » systemctl status zrepl.service 3 ↵
× zrepl.service - zrepl daemon
└─overrides.conf
Active: failed (Result: exit-code) since Mon 2024-04-01 18:08:31 CEST; 5min ago
Process: 1730 ExecStartPre=/nix/store/hnwbdspbqacr1b84c2q0ziss93k21mvs-zrepl-0.6.1/bin/zrepl --config /etc/zrepl/zrepl.yml configcheck (code=exited, status=1/FAILURE)
IP: 0B in, 0B out
CPU: 17ms
apr 01 18:08:31 nixgram systemd[1]: zrepl.service: Scheduled restart job, restart counter is at 5.
apr 01 18:08:31 nixgram systemd[1]: zrepl.service: Start request repeated too quickly.
apr 01 18:08:31 nixgram systemd[1]: zrepl.service: Failed with result 'exit-code'.
apr 01 18:08:31 nixgram systemd[1]: Failed to start zrepl daemon.
there are my configuration for nixos:
configuration.nix
# your system. Help is available in the configuration.nix(5) man page
{ config, pkgs, ... }:
imports =
./hardware-configuration.nix
./users.nix
./desktop.nix
./package.nix
./tlp.nix
./zrepl.nix
boot.loader.grub = {
zfsSupport = true;
efiSupport = true;
efiInstallAsRemovable = true;
mirroredBoots = [
{ devices = [ "nodev"]; path = "/boot/efi"; }
networking.hostId = "00bab10c";
boot.zfs.extraPools = [ "rpool" ];
# Use the systemd-boot EFI boot loader.
#boot.loader.systemd-boot.enable = true;
#boot.loader.efi.canTouchEfiVariables = true;
hardware.bluetooth.enable = true; # enables support for Bluetooth
hardware.bluetooth.powerOnBoot = true; # powers up the default Bluetooth controller on boot
services.blueman.enable = true;
hardware.bluetooth.settings = {
General = {
Experimental = true;
networking.hostName = "nixgram"; # Define your hostname.
# Pick only one of the below networking options.
# networking.wireless.enable = true; # Enables wireless support via wpa_supplicant.
# networking.networkmanager.enable = true; # Easiest to use and most distros use this by default.
nixpkgs.config.allowUnfree = true; #needed for nvidia drivers
# tlp service
services.tlp.enable = true;
services.power-profiles-daemon.enable = false;
services.zrepl.enable = true;
services.zrepl.package = pkgs.zrepl;
services.packagekit.enable = true;
# thunderbolt
services.hardware.bolt.enable = true;
# Set your time zone.
time.timeZone = "Europe/Rome";
i18n.defaultLocale = "it_IT.UTF-8";
console = {
font = "Lat2-Terminus16";
# keyMap = "it";
useXkbConfig = true; # use xkbOptions in tty.
# Configure keymap in X11
# services.xserver.layout = "it";
# services.xserver.xkbOptions = {
# "eurosign:e";
# "caps:escape" # map caps to escape.
# services.printing.enable = true;
# Enable sound.
sound.enable = true;
hardware.pulseaudio.enable = true;
services.xserver.libinput.enable = true;
programs.zsh.enable = true;
users.extraUsers.root = {
shell = pkgs.zsh;
# $ nix search wget
# environment.systemPackages = with pkgs; [
# vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
# wget
# started in user sessions.
# programs.mtr.enable = true;
# programs.gnupg.agent = {
# enable = true;
# enableSSHSupport = true;
# Enable the OpenSSH daemon.
# Open ports in the firewall.
# Copy the NixOS configuration file and link it from the resulting system
# (/run/current-system/configuration.nix). This is useful in case you
# accidentally delete configuration.nix.
# system.copySystemConfiguration = true;
system.stateVersion = "23.11"; # Did you read the comment?
and this zrepl.nix:
{ config, pkgs, lib, ... }:
jobs = [
name = "snapjob";
type = "snap";
filesystems = {
"rpool/root/nixos"= true;
"rpool/data/nixos-home"= true;
"rpool/data/condivise"= true;
snapshotting = [
type = "periodic";
interval= "30m";
prefix= "zrepl_snapjob_";
pruning=
keep = [
type= "last_n";
count= "20";
and there are my dataset:
[18:13:51] zar_marco :: nixgram ➜ ~ » zfs list 3 ↵
NAME USED AVAIL REFER MOUNTPOINT
rpool 268G 631G 96K none
rpool/data 167G 631G 96K none
rpool/data/arch-home-old 18.7G 631G 16.9G legacy
rpool/data/condivise 122G 631G 122G legacy
rpool/data/gentoo-home 2.55G 631G 1.93G legacy
rpool/data/gentooD-home 11.1G 631G 10.5G legacy
rpool/data/gentoorc-home 1.84G 631G 1.32G legacy
rpool/data/nixos-home 1.00G 631G 1.00G legacy
rpool/data/void-home 10.3G 631G 8.44G legacy
rpool/root 101G 631G 96K none
rpool/root/arch-old 23.5G 631G 16.5G /
rpool/root/gentooD 32.8G 631G 32.3G /
rpool/root/gentoorc 11.6G 631G 10.7G /
rpool/root/nixos 17.0G 631G 17.0G /
rpool/root/void 16.1G 631G 11.5G /
Sorry, but, someone using zrepl? Someone Who ever restored a snapshot?
I can not extract a specific question that I am able to answer here.
Restoring of a snapshot does not have a direct relations to zrepl, it’s just meant for taking snapshots and replicating them.
To restore you need to use the built-in zfs tools.
Raising a specific question or describing a scenario that you are in might help.
It think that we are facing a xy problem otherwise.
Second question is my fault, I’m wrong to write in this thread. Anyway tomorrow I will try with zrepl, because currently zrepl service fault on my system, with error how I wrote a few days ago
You should check what pre checks are failing. That could either be done by manually running them (see command in the systems unit) or check if the fails are mentioned in journalctl -u zrepl
For context, the zrepl service checks if the configuration is valid before starting. That seems not to be the case for your config according the provided log snippets
apr 01 18:08:31 nixgram systemd[1]: zrepl.service: Failed with result ‘exit-code’.
I don’t understand these three errors
Systemd is saying that it tried to start zrepl 5 times and now stop doing so, as it stopped “to quickly” as it never has started.
That is all just partly related to zrepl. Those are logs from systemd.
Zrepl is not starting due to the failing pre check (according the log you showed few days ago).
The task is to check what the configcheck
(preStart command) is complaining about.
░░ L'unità zrepl.service ha iniziato la fase di avvio.
apr 26 10:49:20 nixgram zrepl[3874]: could not parse config: yaml: unmarshal errors:
apr 26 10:49:20 nixgram zrepl[3874]: line 8: cannot unmarshal !!seq into struct { Type string }
apr 26 10:49:20 nixgram zrepl[3874]: line 1: field pruning is required but not given
apr 26 10:49:20 nixgram zrepl[3874]: line 1: field snapshotting is required but has zero value
apr 26 10:49:20 nixgram zrepl[3874]: line 0: field jobs is required but has zero value
apr 26 10:49:20 nixgram systemd[1]: zrepl.service: Control process exited, code=exited, status=1/FAILURE
I’ve these errors, have I problems with configs?
Yes, your current configuration is invalid for zrepl.
Which exact problems it has, is shown there per line.
Be aware that zrepl inspects the zrepl.yaml in /etc/zrepl that is generated from your nix configuration (so you need to translate it to your nix config).
For that I recommend to compare the generated yaml with your nix config.
Really I don’t understand, this is my configuration.nix with zrepl config
imports =
./users.nix
./desktop.nix
./package.nix
./tlp.nix
#./zrepl.nix
zfsSupport = true;
efiSupport = true;
mirroredBoots = [
{ devices = [ "nodev"]; path = "/boot"; }
boot.zfs.extraPools = [ "ipool" ];
boot.kernelParams = [ "zfs.zfs_arc_max=12884901888" ];
# boot.kernelPackages = pkgs.linuxKernel.packages.linux_6_8.zfs;
nixpkgs.config.allowBroken = true;
General = {
# tlp service
system.autoUpgrade.enable = true;
system.autoUpgrade.allowReboot = false;
jobs = [
name = "snapjob";
type = "snap";
filesystems = {
"ipool/nixos/root"= true;
"ipool/nixos/home"= true;
"ipool/condivise"= true;
snapshotting = [
type = "periodic";
interval= "30m";
pruning=
keep = [
type= "last_n";
count= "20";
# thunderbolt
console = {
#keyMap = "it";
# "eurosign:e";
# Enable sound.
#sound.enable = true;
#hardware.pulseaudio.enable = true;
security.rtkit.enable = true;
services.pipewire = {
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
jack.enable = true;
shell = pkgs.zsh;
users.extraUsers = {
marco = {
isNormalUser = true;
uid = 1000;
extraGroups = [ "wheel" "users" "networkmanager" ];
shell = pkgs.zsh;
# $ nix search wget
# wget
# enable = true;
system.stateVersion = "24.05"; # Did you read the comment?
this is /etc/zrepl/zrepl.yml
│ File: /etc/zrepl/zrepl.yml
1 │ jobs:
2 │ - filesystems:
3 │ ipool/condivise: true
4 │ ipool/nixos/home: true
5 │ ipool/nixos/root: true
6 │ name: snapjob
7 │ snapshotting:
8 │ - interval: 30m
9 │ prefix: zrepl_snapjob_
10 │ pruning:
11 │ keep:
12 │ - count: '20'
13 │ type: last_n
14 │ type: periodic
15 │ type: snap
how wrong?
for example, this is my configuration on arch
1 │ jobs:
2 │ - name: snapjob
3 │ type: snap
4 │ filesystems: {
5 │ "ipool/arch/root": true,
6 │ "ipool/arch/home": true,
7 │ "ipool/condivise": true,
8 │ }
9 │ snapshotting:
10 │ type: periodic
11 │ interval: 30m
12 │ prefix: zrepl_snapjob_
13 │ pruning:
14 │ keep:
15 │ - type: last_n
16 │ count: 20
I think that problem is how configuration.nix write /etc/zrepl/zrepl.yml
There is an “error” in your nix config here.
As nix does not know what a valid zrepl yaml looks like, it can not tell you when building the config.
That does the configcheck
on service start.
Try this snippet
config,
pkgs,
lib,
jobs = [
name = "snapjob";
type = "snap";
filesystems = {
"rpool/root/nixos" = true;
"rpool/data/nixos-home" = true;
"rpool/data/condivise" = true;
snapshotting = {
type = "periodic";
interval = "30m";
prefix = "zrepl_snapjob_";
pruning = {
keep = [
type = "last_n";
count = 20;
That should translate to the same config like the arch snippet that you have provided.
I recommend, that you use a formatter that is capable to format some nix code, then you might have spotted the problem quite easily (i assume that its not formatted, as you pasted it to the discourse unformatted)
Thanks so much, I made an error with [ ]
