Home Manager and Nixpkgs mismatched versions
Hello everyone,
I just set up home-manager as a module via flake and everything seems to work, but I get a warning everytime I run “sudo nixos-rebuild switch”:
evaluation warning: lain profile: You are using
                  Home Manager version 25.11 and
                  Nixpkgs version 25.05.
                Using mismatched versions is likely to cause errors and unexpected
                behavior. It is therefore highly recommended to use a release of Home
                Manager that corresponds with your chosen release of Nixpkgs.
                If you insist then you can disable this warning by adding
                  home.enableNixpkgsReleaseCheck = false;
                to your configuration.
I tried following the suggestion and specified the home-manager release in my flake.nix:
    nixpkgs.url = "github:nixos/nixpkgs/nixos-25.05";
    home-manager = {
      url = "github:nix-community/home-manager/release-25.05";
  outputs = { self, nixpkgs, ... }@inputs: {
    nixosConfigurations.NAVI = inputs.nixpkgs.lib.nixosSystem {
      specialArgs = {inherit inputs;};
      modules = [
        ./configuration.nix
        inputs.home-manager.nixosModules.default
After sudo nix flake update and sudo nixos-rebuild switch I get a new error:
error:
     at /nix/store/hr5pl7m833kkr0zv98iydy7mxyl10qld-source/lib/attrsets.nix:1571:13:
     1570|           if length values == 1 || pred here (elemAt values 1) (head values) then
     1571|             head values
     1572|           else
     at /nix/store/hr5pl7m833kkr0zv98iydy7mxyl10qld-source/lib/modules.nix:1083:7:
     1082|     // {
     1083|       value = addErrorContext "while evaluating the option `${showOption loc}':" value;
     1084|       inherit (res.defsFinal') highestPrio;
   … while evaluating the option `system.build.toplevel':
   … while evaluating definitions from `/nix/store/hr5pl7m833kkr0zv98iydy7mxyl10qld-source/nixos/modules/system/activation/top-level.nix':
   … while evaluating the option `assertions':
   … while evaluating definitions from `/nix/store/a4la088hi5id7sw77gy9zdvwn83dgczz-source/nixos/common.nix':
   error: The option `home-manager.users.lain.programs.git.settings' does not exist. Definition values:
   - In `/nix/store/sxkw0l6qlfd043siqwlyljivw94vil6h-source/home.nix':
         credential = {
           helper = "libsecret";
         user = {
This didn’t happen when in the flake.nix home-manager url was set as url = "github:nix-community/home-manager";
My almost unmodified home.nix:
{ config, pkgs, ... }:
  home.username = "lain";
  home.homeDirectory = "/home/lain";
  home.stateVersion = "25.05"; # Please read the comment before changing.
  home.packages = [
  programs.git = {
    package = pkgs.git.override { withLibsecret = true; };
    settings.user = {
        name  = "InOnesGraveDed";
        email = "myemail@disroot.org";
    settings = {
      credential.helper = "libsecret";
  home.file = {
  home.sessionVariables = {
Everything is working as intended.
The error that you get is telling you that the option “programs.git.settings”, that you use, doesn’t exist. I just checked and indeed this option does not exist in release-25.05 of home manager.
It worked before because you used the recent unstable release that includes that option.
I hope this is clear. You have three options, ignore the warning and mix home manager unstable with nixos release 25.05, switch to unstable or remove that option.
Oh, I see, thanks for clarification.
I was confused because the wiki specifies the 25.05 release, but then in the Usage section, it shows “programs.git.settings”. That seemed a bit misleading to me…
Clearly an oversight of the writer of that article. Thanks for pointing that out
You should probably stick with 25.11 (unstable, for now) since 25.05 is going to be deprecated in a couple of weeks anyway.
I agree on sticking with unstable for now - it looks like release-25.11 will become available on the 25th as per the current schedule: NixOS 25.11 – Release schedule · Issue #443568 · NixOS/nixpkgs · GitHub
