Home-Manager as module help
Hi everyone, I’m trying to setup home-manger as a module in my flake.
I am getting the following error while trying to rebuild and I’m a bit lost:
       error: A definition for option `home-manager.users.modules' is not of type `Home Manager module'. Definition values:
       - In `/nix/store/ws4gp4ahcmjdbyf9p1rlpmw42pzgziak-source/hosts/homebase/home-manager.nix':
             /nix/store/ws4gp4ahcmjdbyf9p1rlpmw42pzgziak-source/hosts/homebase/home.nix
             /nix/store/ws4gp4ahcmjdbyf9p1rlpmw42pzgziak-source/homeManagerModules
My current directory structure is as follows:
 ~/nixosConfig   master ~ •  ➜  tree .
├── flake.lock
├── flake.nix
├── homeManagerModules
│   ├── alacritty.nix
│   ├── default.nix
│   ├── desktop.nix
│   ├── direnv.nix
│   ├── nixpkgs.nix
│   ├── starship.nix
│   ├── tmux.nix
│   └── zsh.nix
├── hosts
│   └── homebase
│       ├── bluetooth.nix
│       ├── configuration.nix
│       ├── hardware-configuration.nix
│       ├── home-manager.nix
│       ├── home.nix
│       └── nvidia.nix
My flake.nix has the following relevant lines:
  outputs = { self, nixpkgs, ... }@inputs : {
      nixosConfigurations.nixos = nixpkgs.lib.nixosSystem {
          specialArgs = { inherit inputs; };
          modules = [
              ./hosts/homebase/configuration.nix
              ./nixosModules
      homeManagerModules.default = ./homeManagerModules;
My configuration.nix imports home-manager.nix which has the following contents:
{inputs, ...}:
let user = "<my_username>";
    home-manager = {
        extraSpecialArgs = { inherit inputs; };
        users = {
            "${user}" = import ./home.nix;
            modules = [
                ./home.nix
                inputs.self.outputs.homeManagerModules.default
And finally my home.nix is as follows:
{ config, pkgs, ... }@inputs:
    imports = inputs.self.outputs.homeManagerModules.default;
    # Home Manager needs a bit of information about you and the paths it should
    # manage.
    home.username = "<my_username>";
    home.homeDirectory = "/home/<my_username>";
    # This value determines the Home Manager release that your configuration is
    # compatible with. This helps avoid breakage when a new Home Manager release
    # introduces backwards incompatible changes.
    # You should not change this value, even if you update Home Manager. If you do
    # want to update the value, then make sure to first check the Home Manager
    # release notes.
    home.stateVersion = "24.05"; # Please read the comment before changing.
and homeManagerModules/default.nix:
{lib, ...}:
    imports = [
        ./nixpkgs.nix
        ./alacritty.nix
        ./zsh.nix
        ./starship.nix
        ./tmux.nix
        ./direnv.nix
        ./desktop.nix
What on earth could I be doing wrong here aha
You are telling HM to manage the user modules, I think you actually want home-manager.sharedModules, not home-manager.users.modules.
Or if the modules are not meant to be shared across all users, put them into the imports list of the user who is supposed to use them.
Are you saying something like this?
{inputs, ...}:
    home-manager = {
        users = {
            # "${user}" = import ./home.nix;
            "${user}" = {
                imports = [
                    ./home.nix
