I recently started getting this message when running home-manager switch --flake .
Home Manager not found at /nix/store/vl5cx74q6n8m7dhxnyx1qpfgiwgifax2-source.
I am also getting this:
error: file 'home-manager/home-manager/build-news.nix' was not found in the Nix search path (add it using $NIX_PATH or -I)
at «none»:0: (source not available)
Any thoughts?
same problem here (home-manager with flakes)
is this on nixos? did you use the flake to init like said here? Home Manager Manual
is home-manager managing itself? as this is about flake if in a git repo is every file tracked?
Currently I use Home Manager stand-alone via flake on macOS. I rebuild HM via home-manager switch --flake ~/.config/home-manager
and update it via nix flake update ~/.config/home-manager
. Every file is git-added.
Yes, this is on nixos. I have been running nixos for more than a year, and this just started happening.
