I am using home-manager within my nix-darwin configuration file.
Like shown here.
I have set up programs, home.packages, home.stateVersion,
Everything works EXCEPT home.sessionVariables and home.shellAliases.
home.sessionVariables = { EDITOR = "nvim"; };
home.shellAliases = { asl = "aws sso login"; };
When I rebuild for some reason these two things are not set.
Any ideas?
Further context:
This is my darwin-configuration.nix file:
{ config, pkgs, ... }:
nix.extraOptions = "experimental-features = nix-command flakes";
wget
vim
services.nix-daemon.enable = true;
programs.zsh.enable = true; # default shell on catalina
system.stateVersion = 4;
# System Configurations
environment.loginShell = pkgs.zsh;
fonts.fonts = [
(pkgs.nerdfonts.override { fonts = [ "Meslo" "FiraCode" "FiraMono" ]; })
system.defaults.NSGlobalDomain."com.apple.mouse.tapBehavior" = 1;
system.defaults.NSGlobalDomain."com.apple.swipescrolldirection" = false;
system.defaults.dock.autohide = true;
system.defaults.dock.static-only = true;
system.defaults.dock.wvous-bl-corner = 2; # Bottom-Left hot corner is "Mission Control"
system.defaults.finder.AppleShowAllExtensions = true;
# Home Manager configurations
imports = [ <home-manager/nix-darwin> ];
users.users.<user> = {
name = "<user>";
home = "/Users/<user>";
home-manager.users.<user> = { pkgs, ... }: {
programs = {
fzf = {
enableZshIntegration = true;
gh = {
settings = {
git_protocol = "ssh";
prompt = "enabled";
neovim = {
defaultEditor = true;
vimAlias = true;
home.packages = with pkgs; [
bat
tree
home.stateVersion = "22.05";
As you can see I am doing both nix-darwin and home-manager in the same file.
My shell doesn’t have access to home-manager switch, I have to do darwin-rebuild switch to rebuild both.
Please let me know what might be going wrong.
