I’m trying to figure out the optimal power settings for my home server. Currently the fan is running nonstop without any temperature or load on the CPU.
I set:
systemd.targets = {
sleep.enable = false;
suspend.enable = false;
hibernate.enable = false;
hybrid-sleep.enable = false;
to keep the server awake.
I also tried powerManagement.enable = false;
and powerManagement.powertop.enable = true;
. Is this a primarily used in laptops?
Powertop seems happy with my setup as far as I can tell.
My machine is a HP EliteDesk 800 G2 with and i5-6500.
Is this even something I can manage on an OS level or do I need to change something in the BIOS.
Did you configure powertop or just enable it?
Correct, the powerManagement
settings are most useful for laptops or desktops where you want suspend/hibernate. If you care about power usage then powertop
can still be useful.
Very few desktop motherboards allow userspace control the fans; most only allow setting the fan speed/curves via the BIOS.
You can try lm-sensors
to control fans but TBH it often doesn’t work: Fan speed control - ArchWiki
by default enables auto tuning. I mainly checked that every status says good
. This was already the case except for 2 devices which I disconnected anyways.
I tried to use the instructions from ArchWiki, but had a problem where detect-sensors
didn’t write out the configuration file and sensors
didn’t show any fan. I tried changing the divisor but just got an error.
