home.shellAliases unable to set aliases using home-manager
I have set up home-manager like this inside my nix-darwin.
Every thing is working perfectly except for the shellAliases part.
  # Home Manager configurations
  imports = [ <home-manager/nix-darwin> ];
  users.users.<user> = {
    name = "<user>";
    home = "/Users/<user>";
  home-manager.users.<user> = { pkgs, ... }: {
    home = {
      shellAliases = {
          asl = "aws sso login";
      packages = with pkgs; [
        btop
        direnv
        gh
        neovim
        nixfmt
        tree
        zoxide
        bat
        lazygit
        delta
        ripgrep
        cargo
        speedtest-cli
      stateVersion = "22.05";
The packages are working, but the alias is not.
What could be the issue?
I don’t know the problem - what is the exact symptom you’re seeing? - but you could try setting a shell-specific alias instead. I presume you’ve somehow arranged for aws to be on your $PATH?
Yes, aws works.
By the “alias is not” working, I meant that that on executing asl it can’t recognise it at all.
asl
zsh: command not found: asl
I intended to move this alias from my .zshrc to home.shellAliases because I understand that this way, these aliases will accessible from other shells like fish as well right?
