There’s this project that I want to install.
It is a module that allows openssl to work with russian national standart ciphers (GOST). The result of its compilation is an openssl module, that it then tries to add to the directory where other modules are stored, before promptly failing because the nix-store is read-only.
How can I install this additional module “the nix way”?
I have tried writing the followind build script
nixpkgs = import <nixpkgs> {};
inherit (nixpkgs) stdenv git cmake openssl;
gost-engine = stdenv.mkDerivation {
name = "gost-engine";
buildInputs = [git cmake openssl];
src = builtins.fetchGit {
"url" = "https://github.com/gost-engine/engine.git";
"rev" = "2a8a5e0ecaa3e3d6f4ec722a49aa72476755c2b7";
submodules = true;
cmakeFlags = [
"-DOPENSSL_ENGINES_DIR=${openssl}/lib/engines-3"
buildPhase = ''
cmake -DCMAKE_BUILD_TYPE=Release ..
cmake --build . --config Release
in gost-engine
and it fails with this error
