For context, I am using nix-minecraft to configure a Minecraft server on my system. I would like to configure some more secure defaults, as Minecraft has some relatively insecure settings by default. The services.minecraft-servers.servers
option is defined as a types.attrsOf (types.submodule {...})
type. I’ve tried the following configuration, which was intended to get a list of defined servers from the services.minecraft-servers.servers
option and use it to generate defaults for any server that is defined.
{ pkgs, lib, config, ... }:
config = lib.mkMerge [
(lib.mkIf config.services.minecraft-servers.enable {
services.minecraft-servers.servers = lib.genAttrs (builtins.attrNames config.services.minecraft-servers.servers)
(_: {
serverProperties = {
# Use whitelist.
white-list = lib.mkDefault true;
enforce-whitelist = lib.mkDefault true;
# Disables chat reporting requirement; does nothing to aid in
# security and only serves to make the server less private.
enforce-secure-profile = lib.mkDefault false;
# Require online authentication for users.
online-mode = lib.mkDefault true;
What I was intending to do with the above is to configure my system so that any server defined in services.minecraft-servers.servers
would have the default options defined above in serverProperties
. However, this just results in an infinite recursion:
warning: Git tree '/home/nullbite/nixfiles' is dirty
error:
at /nix/store/cp5s6lac68bzypgc1chl8c0ss3rqxi27-source/lib/attrsets.nix:1541:11:
1540| || pred here (elemAt values 1) (head values) then
1541| head values
1542| else
at /nix/store/cp5s6lac68bzypgc1chl8c0ss3rqxi27-source/lib/modules.nix:809:9:
808| in warnDeprecation opt //
809| { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
810| inherit (res.defsFinal') highestPrio;
error: infinite recursion encountered
Is there any other way I could set default values for submodule options? I can’t think of any way to access the list of defined options to be able to set them without triggering an infinite recursion.
For reference, the option type is defined here.
