How can I connect to wifi after resuming from suspension?
I would like to my NixOS run these commands after resuming from suspension:
    echo "Connecting to Wifi after resuming."
    sleep 5
    rmmod iwldvm iwlwifi
    modprobe iwldvm iwlwifi
    sleep 1
    nmcli connection up Redmi
    echo "end of connecting to Redmi"
Does anyone know why this command doesn’t work for me?
You might need to give the full path (thus the package), by default system doesn’t have a PATH which includes for example “nmcli” command as far as I know.
Here is a part from my config:
    resumeCommands = ''
      ${pkgs.utillinux}/bin/rfkill unblock wlan
