…I do see it suddenly pop up as connected, then just as suddenly, it disappears from that list, so something goes wrong. I need to find a log of this.
I think first I need to figure out how to start bluetoothd with debugging enabled
-d, --debug=<file1>:<file2>:...
Sets how much information bluetoothd sends to the log destination (usually syslog's "daemon" facility). If the file options are omitted, then debugging information from all the source files are printed. If file options are present, then only debug prints from that source file are printed. The option can be a pattern containing "*" and "?" characters.
Example: --debug=src/adapter.c:src/agent.c
