Hello I am trying to package maccel
This is what I’ve come up with so far (Most of this is from the nix wiki)
stdenv,
pkgs,
lib,
fetchFromGitHub,
kernel,
kmod,
stdenv.mkDerivation rec {
pname = "maccel";
version = "0.2.1";
src = fetchFromGitHub {
owner = "Gnarus-G";
repo = "maccel";
rev = "v${version}";
hash = "sha256-j6rxNGhRRah6RkZc0KORJfwSgpSQONMK2LgZ5WBMWxA=";
sourceRoot = "source/";
hardeningDisable = ["pic" "format"]; # 1
nativeBuildInputs = [kernel.moduleBuildDependencies pkgs.sudo]; # 2
makeFlags = [
"KERNELRELEASE=${kernel.modDirVersion}" # 3
"KDIR=${kernel.dev}/lib/modules/${kernel.modDirVersion}/build" # 4
"MODULEDIR=${kernel.dev}/lib/modules/"
"INSTALL_MOD_PATH=$(out)" # 5
meta = {
description = "Mouse acceleration driver and kernel module for Linux.";
homepage = "https://github.com/Gnarus-G/maccel";
license = lib.licenses.gpl2;
platforms = lib.platforms.linux;
This returns the error
sudo: The "no new privileges" flag is set, which prevents sudo from running as root.
The Makefile extensively uses sudo, I do not know how to proceed.
Maybe fork the repo and remove all sudo usages?I think it would work but it would be a pain to maintain.
Or maybe try to “fake” sudo
none of the sudo usage is needed for non-imperative installs. you should be able to just remove it. something like this should work for patching the makefile
prePatch = ''
substituteInPlace Makefile \
--replace "sudo" ""
depending on how much needs to be changed apart from that a patch-file might make more sense in the end.
Atemu
January 9, 2025, 12:43pm
3
An alternative is to add a fake “sudo” to nativeBuildInputs which just execs its arguments without privilege escalation:
pkgs.runCommand "sudo" { } ''exec "$@"''
Celibistrial:
pkgs,
pkgs should never be used as a package expression argument, btw, list out the attributes under pkgs instead!
See Package parameters and overrides with callPackage — nix.dev documentation for more context.
Thank you that seems to work!
Now I’ve hit another issue
stdenv,
pkgs,
lib,
fetchFromGitHub,
kernel,
kmod,
pname = "maccel";
version = "0.2.1";
owner = "Gnarus-G";
repo = "maccel";
prePatch = ''
--replace "sudo" ""
pkgs.klibcShrunk
makeFlags = [
"MODULEDIR=$out/lib/modules/${kernel.modDirVersion}/kernel/drivers/usb"
"DRIVERDIR=${src}/driver/"
"CC=${stdenv.cc.targetPrefix}gcc"
meta = {
It tries to create files in DRIVERDIR folder but it cannot as DRIVIERDIR points to the source.
I tried copying the files to $NIX_BUILD_TOP ( which i think is writable?)
preBuild = ''
mkdir -p $NIX_BUILD_TOP/src
cp -r ${src} $NIX_BUILD_TOP/src/
cp -r ${kernel.dev}/lib $NIX_BUILD_TOP/
makeFlags = [
"KDIR=$NIX_BUILD_TOP/lib/modules/${kernel.modDirVersion}/build"
"DRIVERDIR=$NIX_BUILD_TOP/src/driver/"
but now make tries to enter /build/source
maccel> make CC=gcc EXTRA_CFLAGS= -C IX_BUILD_TOP/lib/modules/6.12.5/build M=IX_BUILD_TOP/src/driver/
maccel> make[1]: Entering directory '/build/source'
maccel> make[1]: *** IX_BUILD_TOP/lib/modules/6.12.5/build: No such file or directory. Stop.
Atemu
January 9, 2025, 6:00pm
6
You’re in the source dir by default after unpackPhase, just use $(pwd).
You generally never want to reference src anywhere except a custom unpackPhase.
I tried to use that initially but i wasn’t able to get it to work
pkgs.klibcShrunk
(pkgs.runCommand "sudo" {} ''exec "$@"'')
The above returns
sudo> building '/nix/store/63qnzji6ryxlmfmhp03sm8hv18malzs6-sudo.drv'
error: builder for '/nix/store/63qnzji6ryxlmfmhp03sm8hv18malzs6-sudo.drv' failed to produce output path for output 'out' at '/nix/store/63qnzji6ryxlmfmhp03sm8hv18malzs6-sudo.drv.chroot/root/nix/store/w24x6ylyxrknnkxzy8kkgjnhvwn4qgq8-sudo'
Whats the correct way to use the snippet you provided?
Atemu
January 9, 2025, 6:11pm
8
Ah sorry, I don’t know what I was thinking. This needs to be writeShellScriptBin of course:
(writeShellScriptBin "sudo" ''exec "$@"'')
