I am trying to build the apache web-server with modsecurity included by default. The modsecurity_standalone
package removes the default behavior of copying the library file into apache’s modules
folder.
I stumbled upon a way by overriding the attributes passed to mkDerivation
pkgs = ((import (fetchTarball https://github.com/NixOS/nixpkgs/archive/staging.tar.gz)) {});
modsecurityApache = pkgs.modsecurity_standalone.overrideAttrs (
oldAttrs: rec {
# disable the patch file that removes copying this into
# apache's modules directory
patches = [];
pkgs.mkShell {
buildInputs = [ pkgs.apacheHttpd modsecurityApache ];
I created this snippet as my-httpd.nix
. I then ran nix build -f my-httpd.nix
It fails when compiling the modsecurityApache
derivation:
$ nix build -f innovu-httpd.nix
[12.5/0.0 MiB DL] downloading 'https://github.com/NixOS/nixpkgs/archive/staging.[15.1/0.0 MiB DL] downloading 'https://github.com/NixOS/nixpkgs/archive/staging.[16.3/0.0 MiB DL] downloading 'https://github.com/NixOS/builder for '/nix/store/5s997iwck55mlg2fbv3zg7hzmk05zwc3-modsecurity-2.9.3.drv' failed with exit code 2; last 10 log lines:
make[3]: Entering directory '/build/modsecurity-2.9.3/apache2'
Removing unused static libraries...
install: cannot create regular file '/nix/store/9z4lsps5k2jncsxbv9625hyppy5z8nkd-apache-httpd-2.4.41/modules/mod_security2.so': Permission denied
make[3]: *** [Makefile:1207: install-exec-hook] Error 1
make[3]: Leaving directory '/build/modsecurity-2.9.3/apache2'
make[2]: *** [Makefile:1144: install-exec-am] Error 2
make[2]: Leaving directory '/build/modsecurity-2.9.3/apache2'
make[1]: *** [Makefile:1087: install-am] Error 2
make[1]: Leaving directory '/build/modsecurity-2.9.3/apache2'
make: *** [Makefile:501: install-recursive] Error 1
cannot build derivation '/nix/store/7xq6cxl021a6g1xg6jjw5p7n2vhzm0v1-nix-shell.drv': 1 dependencies couldn't be built
[2 built (1 failed), 89 copied (419.4 MiB), 127.4 MiB DL]
error: build of '/nix/store/7xq6cxl021a6g1xg6jjw5p7n2vhzm0v1-nix-shell.drv' failed
The key error seems to be this line:
Given nix isolates dependencies this would make sense. A later derivation should not be able to mutate a prior one’s directory structure. But I require each package’s directory structure to be merged into one.
- How would you adjust the above nix expression to achieve what I’m after?
- Are there better ways of solving this problem using alternative nix packaging hooks?
