How do specialArgs work?
New to Nix & NixOS :wave:
When using a flake for my NixOS system’s configuration, is there any difference between using specialArgs this way
  inputs.nixpkgs.url = "github:NixOS/nixpkgs";
  outputs = { nixpkgs, ... } @ inputs : {
    nixosConfigurations.hostname = nixpkgs.lib.nixosSystem {
      system = "x86_64-linux";
      specialArgs = inputs;
      modules = [ ./configuration.nix ];
as opposed to this way?
      specialArgs = { inherit inputs; };
In know the latter is some syntaxic sugar and is equivalent to the following
      specialArgs = { inputs = inputs; };
I tried all three syntax, and from what I’ve seen, they all seem to work :thinking:
I’ve read plenty of (official & non-official) documentations, blog posts, and watched countless videos and talks but I’m still a bit lost. If there’s a good documentation I’ve missed, I’m highly interested as well :+1:
Thanks
From what i can understand from the source, the difference should be that specialArgs=inputs; would pass the individual members as module args while specialArgs={inherit inputs;}; passes inputs itself.
That would be my understanding as well but they both seem to work :thinking:
I need to do more testing to better understand this.
Thanks for the link to the source :+1:
I may have found a hint in @djacu’s excellent Function Arguments - NixOS Modules Lessons
It looks like specialArgs is always passed as an argument as well as all its attributes!
Which seems to be what the line @zimward pointed at do
({ inherit lib options config specialArgs; } // specialArgs)
Which means, pass lib, options, config, specialArgs and “merge” with all the attributes of specialArgs (using the // operator).
