I have made a neovim flake, which includes plugins and custom rc, this is made from unstable, because I need 0.5 version neovim
# neovim flake.nix
description = "neovim wrap";
nixpkgs-unstable.url = github:NixOS/nixpkgs/nixos-unstable;
flake-utils.url = github:numtide/flake-utils;
outputs = { self, ... }@inputs:
inputs.flake-utils.lib.eachDefaultSystem (system:
pkgs = import inputs.nixpkgs-unstable {
overlays = [
(import ./nvim_overlay.nix)
inherit system;
defaultPackage = pkgs.sheeaza.nvim;
overlay = (import ./nvim_overlay.nix);
so the question is how to add this to nixos system flake configurations? I will use stable version 21.05 for my system, and customed unstable neovim.
#system flake.nix
nixpkgs.url = github:NixOS/nixpkgs/nixos-21.05;
nvim.url = "/home/xxx/project/nvim"; # points to the unstable neovim above
outputs = { self, ... }@inputs: {
nixosConfigurations.xxx = inputs.nixpkgs.lib.nixosSystem {
system = "x86_64-linux";
modules = [
./configuration.nix
specialArgs = { inherit inputs; };
hmenke
August 8, 2021, 6:59pm
2
Local flakes can be used with
nvim.url = "path:/home/xxx/project/nvim";
Thanks, and after nvim.url = "path:/home/xxx/project/nvim"; added to inputs, how should I add the nvim package to the configuration.nix
NobbZ
August 9, 2021, 6:09am
4
Pass that (and potentially other inputs) to your _module.args and the you can “pull” the nvim flake from the module arguments and install it.
How I prepare the _module.args can be seen on line 12 of the linked function, though I have to admit, for some reason I do it a bit complicated
And then I just add the inputs as necessary to the modules argset, as can be seen in my “flake enabler”, which by default uses nix from master:
{ config, pkgs, nixpkgs-2105, nix, lib, ... }:
options.nix.flakes.enable = lib.mkEnableOption "nix flakes";
config = lib.mkIf config.nix.flakes.enable {
nix = {
package = lib.mkDefault nix.packages.x86_64-linux.nix; # pkgs.nixUnstable;
experimentalFeatures = "nix-command flakes";
registry.nixpkgs.flake = nixpkgs-2105;
hmenke
August 9, 2021, 6:44am
5
You are forwarding all inputs as arguments to configuration.nix with the line
(which by the way is equivalent to specialArgs = inputs;).
Hence in your configuration.nix you can do
{ config, pkgs, inputs, ... }: {
environment.systemPackages = [ inputs.nvim.defaultPackage.x86_64-linux ];
or if you prefer using your overlay
nixpkgs.overlays = [ inputs.nvim.overlay ];
environment.systemPackages = [ pkgs.neovim ];
NobbZ
August 9, 2021, 7:34am
6
No, it is not , it would be equivalent to specialArgs.inputs = inputs.
Also specialArgs doesn’t compose very well. _module.args should be preferred.
Thanks for this example, but I am still new to nix and this is too complicated for me, I cannot hold this.
NobbZ
August 9, 2021, 4:06pm
8
How exactly is it too complicated?
It is setting some option through the modules argument you pass to your nixosSystem call, then reusing that from your actual module file.
It is just these 2 steps. I could PR that for you if you tell us the location of your repository.
Thanks for your help,
background:
I have learned basicly nix lauguage, like functions, attribute, but I am still puzzled with the predefined nix function. The purpose for me to use nix is simple, to make my development environment totally reproducible, I have gotten tired of repeating configuring system, like editor, cmdline tool stuff
I have uploaded my neovim flake here: https://github.com/sheeaza/nix-nvim , this could basicly work
and system flake here: GitHub - sheeaza/nix-system , this is still in progress and does not work now
NobbZ
August 9, 2021, 4:41pm
10
I did a PR that installs your nvim from the defaultPackage of the nvim flake you provided.
https://github.com/sheeaza/nix-system/pull/1
It built for me without any issues, of course I can not really test it.
PS: In general, I am not a fan of overlays, especially not in combination of flakes. If something can be done without them, I do it without them.
Oh! Oh? Can you expand on this? Thanks!
Also, isn’t it possible that the actual package consumption is less-trivial? I find myself often having to do:
inputs.nvim.packages.x86_64-linux.neovim
NobbZ
August 10, 2021, 4:57am
12
I do not really understand it, though thats what I read from this comment, which one eventually ends up reading if one follows the implementation of nixosSystem:
, # This should only be used for special arguments that need to be evaluated
# when resolving module structure (like in imports). For everything else,
# there's _module.args. If specialArgs.modulesPath is defined it will be
# used as the base path for disabledModules.
specialArgs ? {}
Also, I read somewhere, that extraArgs and specialArgs do not compose well and forbid the use of _module.args, while one can use _module.args in many modules and it will properly merge.
If it is just for one or two packages, I tend to do it like this and write the attributes out fully. If it is more than that I use let or with with a narrow scope.
Thanks again for your help, it works now, I will continue on bringing up tmux fish config.
I would just like to mention that a very similar situation lead me to start using DevOS as a system for managing A flakes-based NixOS config.
I find the vanilla experience extremely un-ergonomic and DevOs provides a nice wrapper that allows you to access things in a much more intuitive way.
Under that system there are simple ways to add packages or overlays to the nixpkgs you’re passing around to modules.
