I built a simple “Hello, World package”, using nix-build -A khello. The executable ends up in result/bin/khello, so I can run it specifying the full path. However, how can I add this package to PATH, so that I can call it with khello?
# khello
khello: command not found
# ./result/bin/khello
Hello, World!
OK, after trying different things I have manged to achieve what I wanted. However, it feels “off” doing it this way, so hopefully there is a better way. Anyway, this is what I did:
I had to create a symlink from .nix-defexpr to my package directory (it did not work using the package root, so possibly every package dir has to be linked up in a similar way): ln -s /home/.pkgs/khello /root/.nix-defexpr/pkgs_khello
I had to build using nix-env instead of nix-build (what is the difference?): nix-env -iA pkgs_khello.khello
Then, a new generation was created (nix-env --list-generations) and khello was “available on the PATH”, or: a symlink from ~/.nix-profiles/bin/ was created pointing to the khello binary.
Using nix-env to install might even be wrong when using Flakes. However, doing it this way seems to work.
