I want to add ibus-bamboo engine at GitHub - BambooEngine/ibus-bamboo: Bộ gõ tiếng Việt cho Linux as an ibus input method engine in NixOS. I have created ibus-bamboo.nix
as following:
{ fetchFromGitHub, stdenv, go, xorg, gnused }:
stdenv.mkDerivation rec {
pname = "ibus-bamboo";
version = "v0.6.5";
src = fetchFromGitHub {
owner = "BambooEngine";
repo = "ibus-bamboo";
rev = "3f4c148228c239c80d787cca207604f6acd95660";
sha256= "00fs9mlcvyrybm356q7yl5g2s03j6drsgc82qkx5hx73i56pyd0j";
buildInputs = [ go xorg.libX11 xorg.libXtst xorg.libXi ];
GOCACHE="/tmp/gocache";
DESTDIR="$out";
patchPhase = "sed -i 's|PREFIX=/usr|PREFIX=|' Makefile && cat Makefile";
buildPhase = "GOCACHE=/tmp/gocache make build";
installPhase = "DESTDIR=$out GOCACHE=/tmp/gocache make install";
fixupPhase = ''
sed -i "s|/usr/lib/ibus-engine-bamboo|$out/lib/ibus-engine-bamboo|" $out/share/ibus/component/bamboo.xml
sed -i "s|/usr/share/ibus-bamboo|$out/share/ibus-bamboo|" $out/share/ibus/component/bamboo.xml
meta = with stdenv.lib; {
isIbusEngine = true;
description = "IBus interface to the vietnamese input method";
homepage = "https://github.com/BambooEngine";
license = licenses.gpl2Plus;
platforms = platforms.linux;
and have these lines in in configuration.nix
{ config, lib, pkgs, ... }:
myPkgOverlay = self: super: {
bamboo = pkgs.callPackage ./ibus-bamboo.nix {};
nixpkgs.overlays = [ myPkgOverlay ];
i18n.inputMethod = {
enabled = "ibus";
ibus.engines = with pkgs; [ ibus-engines.m17n bamboo ];
After run nixos-rebuild switch
and reboot the machine, I found ibus bamboo installed into /nix/store/r8h14gqhxn1qqvp05j2v4z957g36vlk0-ibus-bamboo-v0.6.5
and I also found m17n in ibus list-engine
output, but ibus-bamboo does not appear in the list. What did I do wrong?
update 1: un-comment buildPhase
and installPhase
, so that the package can be build and install
update 2: update src to latest package and patch Makefile
install prefix. ibus-bambo
now appear in /run/current-system/sw/share/ibus
but not in ibus list-engine
update 3: fixup exec path and icon path in share/ibus/component/bamboo.xml
