Hey everyone,
I need to use “NewComputerModern” font packaged in nixpkgs as cm-unicode in a python program I am running in a container using arion compose. The arion-compose.nix file looks like this:
{ pkgs, ... }:
config.project.name = "jupyter-arion";
config.services = {
jupyter= {
service.image = "jupyter/datascience-notebook:latest";
service.environment = {
JUPYTER_ENABLE_LAB = "yes";
JUPYTER_TOKEN = "docker";
service.ports = [
"8888:8888" # host:container
service.volumes = [ "${builtins.toString ( builtins.getEnv "HOME" )}/Documents/project:/home/jovyan/project"];
service.stop_signal = "SIGINT";
I need to run this on NixOS machines, as well as non-NixOS machines (mostly linux). As I was looking around I found this solution to a similar problem, but I am not sure how to use in my case. Is there any standard way to add packages to containers in general?
Thanks in advance for any help!
