Hi!
tldr: Albert’s plugin requires 2 Python dependencies: pint, inflect. I don’t know how to add them
I wanted to enable Unit Converter (Python) plugin in Albert. However, it cannot be run as it requires additional Python dependencies (pint, inflect):
I thought that I can probably add them by using overrideAttrs
by adding them to buildInputs
like this:
{ config, lib, pkgs, ... }:
customAlbert = pkgs.albert.overrideAttrs
(old: {
buildInputs = old.buildInputs ++ (with pkgs.python3Packages; [
inflect
pint
home.packages = [
customAlbert
# more packages
However, after running home-manager switch
, and then starting Albert (as a new process), it still shows me an information that the packages are missing.
So I guess the packages aren’t available to the plugins.
I looked into Albert’s nixpkgs derivation in repo here, and Albert’s own repo here. And it seems that plugins are installed, because they are included as submodule (they are available in a separate repo).
So I’m not sure how should I approach that
