I ran ssh-copy-id so I can ssh to rajas@gaming-computer without entering the password. I can mount it with this command:
sshfs gaming-computer:/ ~/gaming-computer
I tried using the home manager sftpman option like this:
{ pkgs, ... }:
programs.sftpman = {
mounts = {
gaming-computer = {
host = "gaming-computer";
user = "rajas";
mountOptions = [
"~/gaming-computer"
mountPoint = "/";
defaultSshKey = "~/.ssh/id_ed25519";
package = pkgs.sshfs;
home-manager switch exits successfully but my folder doesn’t get mounted.
I looked at Mount sshf as a user using home-manager but it’s very complicated and I don’t think it has to be that complicated.
Also, any suggestions to having a faster (faster file reads) way of mounting the external folder? It is pretty slow using the sshfs command.
auto-mount can mean a few different things here. using nixos’ fileSystems.<mount-point> options (not home manager) can probably get what you want though.
fileSystems."/home/rajas/gaming-computer" = {
device = "rajas@gaming-computer:/";
fsType = "fuse.sshfs";
options = [
"identityfile=/home/rajas/.ssh/id_ed25519"
"idmap=user"
"x-systemd.automount" #< mount the filesystem automatically on first access
"allow_other" #< don't restrict access to only the user which `mount`s it (because that's probably systemd who mounts it, not you)
"user" #< allow manual `mount`ing, as ordinary user.
boot.supportedFilesystems."fuse.sshfs" = true;
you might also want "noauto" (to not block system boot on this mount), "noCheck", "_netdev"/"x-systemd.requires=network-online.target" "x-systemd.after=network-online.target", "default_permissions", and "uid=####" "gid=###" (get from id command) if you use this method.
i haven’t tried this with a password-protected ssh key though – not sure if that works.
I got it to work after a few changes:
fileSystems."/mnt/gaming-computer" = {
options = [
"identityfile=/root/.ssh/id_ed25519"
"idmap=user"
"_netdev"
- Trying to mount it in my home folder resulted in me not being able to access it without
sudo for some reason
- My ssh key is not password protected
