Is there a better way to troubleshoot rebuild failures? The output of --show-trace at times is just too verbose and then sometimes inconsistent. I will admit I likely do not understand something. Overall I find the process abrasive and far from intuitive.
For example, I just had an output that was 702 lines. . Run the identical command a second time, and it is a cached failure of an attribute without any pointers.
So I guess my questions are:
How can I skip the cached failure so I can get back to the verbose output?
Any tips for digging in on the verbose output? I mean I personally do not find output like the following helpful.
79| vals = map (d: d.value) vdefs;
80| defTypes = map (x: x.type) vals;
81| sameOrNull = x: y: if x == y then y else null;
⦠from call site
When I trolled the output originally, I did not find a reference to any of my files in my repo. So I was not sure where to begin.
Well open to suggestions and education. I have to be doing something wrong here and would like to smooth it out. Tips, tricks, process?
Agree with sentiments expressed here.
Anyone tried putting to chat AI?
The only viable solution to me seems to be edit your script but making only small changes and reverse when you hit an error. (using git/backup increases the work) This makes progress slow and increases the frustration. Then you need to remember to remove all those generations
If this was improved I think more people would invest in looking to move to Nixos as this is I think the biggest pain point.
Iāve done some with GitHub copilot. I would say itās successful maybe 40% of the time. When I started this thread, I just wanted to make sure there wasnāt some nix related tooling or process that I just wasnāt aware of.
i have no solution but the same issue, but for it may help, use nixos-rebuild [...] test instead of switch. you still have to garbage-collect, but you wonāt install that generation.
just in case thereās as misunderstanding: nixos-rebuild [...] test will switch your running-system but it wonāt install to you boot-mechanism like grub or efi.
