I’m totally new to NixOS and still figuring out if I should switch to it or not.
So, I startet to build a configuration which at least works and installs most of the stuff I need: GitHub - TLINDEN/nixos-config: My personal nixos config. This just installs packages, I’m not interested to also install configs at this point. I’ll just checkout my dotfiles repo to have them.
However, I am using a couple of go binaries which are not available as a nix package (or are outdated). So, I want to build by own packages for those tools and integrate them into my nixos configuration.
I started to create a new package with nix flake init -t templates#go-hello. I renamed the package, added a github source, fixed the sha256:
description = "A simple Go package";
inputs.nixpkgs.url = "nixpkgs/nixos-21.11";
outputs = { self, nixpkgs }:
lastModifiedDate = self.lastModifiedDate or self.lastModified or "19700101";
version = builtins.substring 0 8 lastModifiedDate;
supportedSystems = [ "x86_64-linux" ];
forAllSystems = nixpkgs.lib.genAttrs supportedSystems;
nixpkgsFor = forAllSystems (system: import nixpkgs { inherit system; });
packages = forAllSystems (system:
pkgs = nixpkgsFor.${system};
rpnc = pkgs.buildGoModule {
pname = "rpnc";
inherit version;
src = pkgs.fetchFromGitHub {
owner = "tlinden";
repo = "rpnc";
rev = "v2.1.0";
sha256 = "sha256-CojP1a19b2zKfUMp+wN7FFs+SzSoc8sYqKvXTg4RnOA=";
vendorSha256 = "sha256-pQpattmS9VmO3ZIQUFn66az8GSmB4IvYhTTCFn6SUmo=";
devShells = forAllSystems (system:
default = pkgs.mkShell {
buildInputs = with pkgs; [ go gopls gotools go-tools ];
defaultPackage = forAllSystems (system: self.packages.${system}.rpnc);
but it’s not compiling:
% nix flake check
warning: flake output attribute 'defaultPackage' is deprecated; use 'packages.<system>.default' instead
warning: The check omitted these incompatible systems: aarch64-darwin, aarch64-linux, x86_64-darwin
Use '--all-systems' to check all.
% nix build
error: builder for '/nix/store/025sdqn58pxj531hgmqphr1klzfyv1g2-rpnc-20240514-go-modules.drv' failed with exit code 1;
last 10 log lines:
> patching sources
> configuring
> building
> go: downloading github.com/chzyer/readline v1.5.1
> go: downloading github.com/spf13/pflag v1.0.5
> go: downloading github.com/yuin/gopher-lua v1.1.0
> go: downloading github.com/rogpeppe/go-internal v1.11.0
> go: downloading golang.org/x/sys v0.0.0-20220722155257-8c9f86f7a55f
> go: downloading golang.org/x/tools v0.1.12
> internal error: failed to find embedded files of github.com/rogpeppe/go-internal/internal/os/execpath: //go:build comment without // +build comment
For full logs, run 'nix-store -l /nix/store/025sdqn58pxj531hgmqphr1klzfyv1g2-rpnc-20240514-go-modules.drv'.
error: 1 dependencies of derivation '/nix/store/qilj13v4cv63x4hpaiw6fjzj75p74a4r-rpnc-20240514.drv' failed to build
This error message doesn’t make any sense. It occurs if you want to compile newer go code with go 1.16 or less. However, I have 1.22.2 installed on my test nix system and the module in question requires 1.20.
How can I find out, which go version the builder is using? How can I change the version? And why isn’t it just using the one specified in the modules go.mod?
And I’ve got even more questions: let’s assume I get the package build to work, what next: how can I put it into the nixos configuration linked above?
You are using Nixpkgs from its nixos-21.11 branch, which was released in 2021. You probably want to use the latest release branch (nixos-23.11 at the moment) or the unstable branch nixos-unstable.
nix build
error: builder for '/nix/store/82hvy7pli62v19nw9ja9vz446b3iv9rp-rpnc-20240514.drv' failed with exit code 1;
last 10 log lines:
> github.com/chzyer/readline@v1.5.1: is explicitly required in go.mod, but not marked as explicit in vendor/modules.txt
> github.com/rogpeppe/go-internal@v1.11.0: is explicitly required in go.mod, but not marked as explicit in vendor/modules.txt
> github.com/spf13/pflag@v1.0.5: is explicitly required in go.mod, but not marked as explicit in vendor/modules.txt
> github.com/yuin/gopher-lua@v1.1.0: is explicitly required in go.mod, but not marked as explicit in vendor/modules.txt
> golang.org/x/sys@v0.0.0-20220722155257-8c9f86f7a55f: is explicitly required in go.mod, but not marked as explicit in vendor/modules.txt
> golang.org/x/tools@v0.1.12: is explicitly required in go.mod, but not marked as explicit in vendor/modules.txt
> To ignore the vendor directory, use -mod=readonly or -mod=mod.
> To sync the vendor directory, run:
> go mod vendor
The source has no vendor/ dir. Can I pass this flag -mod=mod somehow?
One more thing: is there a way to pre-compute the two sha256 hashes somehow? Can’t be the official way to wait for the error to occur and copy/paste the correct hash can it?
