I have an aarch64 box (machine A) which already run nixos. Initially I built the os locally with ‘nixos-rebuild’, but I now want to build from my beefy x86_64 desktop (machine B) in a bare-bone manner. However switch-to-configuration
doesn’t seem to install the new system to grub menu.
Here’s what I did:
- set up ssh and trusted-public-keys in machine A by running
nixos-rebuild
locally
nix build some-flake#nixosConfigurations.machine-a.config.system.build.toplevel
then nix-copy-closure --to user@machine-a ./result
in machine B.
- because
./result
is a symlink to /nix/store/xxx-nixos-system-machine-a-xxx
, in machine A, I ran /nix/store/xxx-nixos-system-machine-a-xxx/bin/switch-to-configuration switch
The new system (with defined packages and services) does seem to be activated in machine A, just grub menu is not updated. switch-to-configuration boot
seems to have no effect. Did I miss something, or should I use another command?
I built with flake and a recent nixpkgs revision (Feb 22 - f5dad40450d272a1ea2413f4a67ac08760649e89
), btw.
You can do remote activation (after the copying the closure or without copying first):
nixos-rebuild boot --target-host root@$machine-a --build-host localhost --flake some-flake#machine-a
I use a similar workflow (pre-build, copy, activate) for some laptops that are turned off most of the time.
Does that work? It seems that you’d build the system configuration for x86_64
, and then that of course won’t work on aarch64
If it’s built with flakes, then the system architecture won’t be implicit like that, so it will build for the right architecture. Now, how it builds for that architecture is up to @myguidingstar. I assume they have emulation set up with boot.binfmt.emulatedSystems
(which, btw, is incredibly slow; a 16c/32t x86_64 processor emulating aarch64 isn’t much faster at compiling the kernel than a raspberry pi 4).
yeah, I have the emulation enabled, just have problem with boot menu.
So I ended up with remote nixos-rebuild
with remote root
user (unable to sudo remotely is a known issue), similar to what @wamserma suggested.
Reading nixos-rebuild
perl source code (a bit cryptic for me) suggested that the symlinks must be managed with nix-env
before calling switch-to-configuration
