There are plenty of ways to create Nix derivations for Python packages, but I haven’t seen any yet which create something equivalent to ./setup.py sdist bdist_wheel
or poetry build
which can then be uploaded to PyPI.
With buildPython*: store dist (wheel/sdist) in dist output by FRidh · Pull Request #190487 · NixOS/nixpkgs · GitHub a package build will output a dist folder containing a wheel. Note however, that if it contains extension modules, that these will have absolute paths to nix libraries.
I suppose one could make an FHS builder.
Fantastic! Based on the code it looks like that expects there to already be a dist
directory. What generates that, and can I do that easily (aka without waiting for your PR to reach stable)? When running nix-build
in my project the result
directory doesn’t have any dist
folder.
pip builds a wheel. The wheel we then install in $out, and without that PR we discard the wheel.
That makes sense; thanks for the explanation! Do you know what the situation for creating sdist releases is like? I don’t really mind only releasing the wheel, but it seems to be a Python norm to release both source and wheel packages.
Yes, it’s good to also release an sdist. I use the following in case I am using flit as backend
Excellent, but the sdist doesn’t end up in the result
folder with this approach:
$ ls -R result/
result/:
bash-completion bin lib nix-support
result/bash-completion:
vcard
result/bin:
vcard
result/lib:
python3.10
result/lib/python3.10:
site-packages
result/lib/python3.10/site-packages:
vcard vcard-0.15.0.dist-info
result/lib/python3.10/site-packages/vcard:
__init__.py __pycache__ vcard_definitions.py vcard_errors.py vcard_property.py vcard.py vcard_utils.py vcard_validator.py vcard_validators.py
result/lib/python3.10/site-packages/vcard/__pycache__:
__init__.cpython-310.pyc vcard_definitions.cpython-310.pyc vcard_property.cpython-310.pyc vcard_validator.cpython-310.pyc
vcard.cpython-310.pyc vcard_errors.cpython-310.pyc vcard_utils.cpython-310.pyc vcard_validators.cpython-310.pyc
result/lib/python3.10/site-packages/vcard-0.15.0.dist-info:
direct_url.json entry_points.txt INSTALLER LICENSE.txt METADATA RECORD REQUESTED top_level.txt WHEEL
result/nix-support:
propagated-build-inputs
(buildPythonPackage
also does something weird, including a whole bunch of files not in the source tarball (and explicitly excluded in MANIFEST.in
) in the result/lib/python3.10/site-packages/vcard
folder. It’s as if it’s ignoring the src
completely.)
