I’m running NixOS and trying to follow this simple example of usage of PostgreSQL on shuttle.rs.
I have managed to deploy the app on shuttle.rs and have received a postgres://...
URI for the server hosted there. At this point the above instructions blithely state
connect to the database provisioned by Shuttle using pgAdmin using the provided database URI […]
Looking on search.nixos.org I find pgadmin4 which I try to run with nix run nixpkgs#pgadmin4
and it errors with
ERROR : Failed to create the directory /var/lib/pgadmin:
[Errno 13] Permission denied: '/var/lib/pgadmin'
HINT : Create the directory /var/lib/pgadmin, ensure it is writeable by
'<my-local-NixOS-username>', and try again, or, create a config_local.py file
and override the SQLITE_PATH setting per
https://www.pgadmin.org/docs/pgadmin4/8.6/config_py.html
In short, pgadmin4
seems to require manual local changes to the state of my NixOS machine, when all I want to do is to connect to a remote instance of the DB. I do not want to run PostgreSQL locally.
Please help me clear up my confusion.
