I use g++ with -flto to compile two .o file and try to link them together to create a executable.
ld -flto main.o functions.o -o myprogram
it outputs:
/nix/store/rhhll3vwpj38ri72ahrrrvcbkhz4fhh6-binutils-2.40/bin/ld: main.o: plugin needed to handle lto object
/nix/store/rhhll3vwpj38ri72ahrrrvcbkhz4fhh6-binutils-2.40/bin/ld: functions.o: plugin needed to handle lto object
/nix/store/rhhll3vwpj38ri72ahrrrvcbkhz4fhh6-binutils-2.40/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000401000
Run nm main.o, it outputs
nm: main.o: plugin needed to handle lto object
0000000000000001 C __gnu_lto_slim
However, when I switch to g++ and gcc-nm, it works correctly.
For ar, ranlib, it is the same.
It seems that the plugin is not loaded by these tools. Is there any workaround?
My flake.nix:
description = "C/C++ development environment";
utils.url = "github:numtide/flake-utils";
outputs = { self, nixpkgs, ... }@inputs: inputs.utils.lib.eachSystem [
"x86_64-linux"
"i686-linux"
"aarch64-linux"
"x86_64-darwin"
(system:
pkgs = import nixpkgs {
inherit system;
packages = with pkgs; [
autoconf
automake
pkg-config
cmake
bear
clang-tools_16
main.cc
#include "functions.h"
int main() {
int result = addNumbers(5, 10);
return 0;
functions.cc:
int addNumbers(int a, int b) {
return a + b;
functions.h
#ifndef _FUNCTIONS_H
#define _FUNCTIONS_H
int addNumbers(int a, int b);
#endif
