How to debug an overridden dependency when using flakes?
Is there a way to step through an overridden package’s phases when using flakes? I know you can step through an existing flake’s phases by using nix develop <flake>#<output>. Is there a way to do this for a dependency of the current flake?
As an example:
# flake.nix
    nixpkgs.url = "github:nixos/nixpkgs/unstable";
    utils = {
      url = "github:numtide/flake-utils";
  outputs = {
    self,
    nixpkgs,
    utils,
  }: let
    out = system: let
      inherit (pkgs) poetry2nix;
      python = pkgs.python39;
      pythonEnv = poetry2nix.mkPoetryEnv {
        inherit python;
        projectDir = ./.;
        preferWheels = true;
        overrides = poetry2nix.overrides.withDefaults (pyfinal: pyprev: {
          soundfile = pyprev.soundfile.overridePythonAttrs (old: {
            postPatch = "(do some stuff)";
      devShell = pkgs.mkShell {
        buildInputs = [pythonEnv];
    with utils.lib; eachSystem defaultSystems out;
Imagine the soundfile package is having some issues in this flake, and I want to see what my override is doing. I would like to step through the packages phases with my override applied and inspect the directory contents at each phase?
I thought maybe I could set python.pkgs.soundfile as a flake output called soundfile and run nix develop .#soundfile on it, but I get:
error: flake output attribute 'soundfile' is not a derivation
Is there a good way to do this?
Thank you!
