hello, I use nixos-rebuild to deploy my remote nixos like this:
nixos-rebuild switch --fast --flake '.#router' --target-host root@192.168.123.176 --build-host root@nixbuilder
but i have a custom module config like this:
{ lib, config, pkgs, ... }:
with lib;
cfg = config.services.ad-upstream;
options.services.ad-upstream = {
enable = mkOption {
default = false;
description = "Enable AdguardHome upstream service";
path = mkOption {
default = null;
type = types.nullOr types.path;
description = "Path to upstream.sh";
config = mkIf cfg.enable {
systemd.services.ad-upstream = {
description = "AdguardHome upstream service";
after = ["network-online.target"];
serviceConfig = {
ExecStart = cfg.path;
systemd.timers.ad-upstream = {
description = "AdguardHome upstream timer";
wantedBy = ["multi-user.target"];
timerConfig = {
OnCalendar = "*-*-* 5:00";
Unit = "ad-upstream.service";
and module config defined in the configuration.nix :
services.ad-upstream.enable = true;
services.ad-upstream.path = ./upstream.sh;
the ./upstream.sh and the upstream.nix (module) under my configuration.nix directory.
we know that when nixos-rebuild with flake, it will copy the current directory to the /nix/store/xxxx-source, but after i run “nixos-rebuild” to deploy remote machine, the nix/store/xxxx-source not on the target machine. so the services.ad-upstream.path = ./upstream.shconfig will broken because of ./upstream.sh not exist.
any one have idea about this case?
the ad-upstream.service content, and the ExecStart path not exist.
[root@router:/etc/systemd/system]# cat ad-upstream.service
[Unit]
After=network-online.target
Description=AdguardHome upstream service
[Service]
Environment="LOCALE_ARCHIVE=/nix/store/md3q61177ag9r74xp74lv0ka7l5dsf7g-glibc-locales-2.35-224/lib/locale/locale-archive"
Environment="PATH=/nix/store/z2k31yvarhcnlc98a76wm07q7a6ryla5-coreutils-9.1/bin:/nix/store/5pm0j70fz1b2jj6krvxbaamq3v0p5b69-findutils-4.9.0/bin:/nix/store/a1s15jpz7fad571j2cyyczjpnxfnag0k-gnugrep-3.7/bin:/nix/store/sfiyijw1gp063ymv2m4zl58imkrfidsv-gnused-4.9/bin:/nix/store/hhp5rgz71srhcpfh9l3kxal5yh0k4bd4-systemd-252.5/bin:/nix/store/z2k31yvarhcnlc98a76wm07q7a6ryla5-coreutils-9.1/sbin:/nix/store/5pm0j70fz1b2jj6krvxbaamq3v0p5b69-findutils-4.9.0/sbin:/nix/store/a1s15jpz7fad571j2cyyczjpnxfnag0k-gnugrep-3.7/sbin:/nix/store/sfiyijw1gp063ymv2m4zl58imkrfidsv-gnused-4.9/sbin:/nix/store/hhp5rgz71srhcpfh9l3kxal5yh0k4bd4-systemd-252.5/sbin"
Environment="TZDIR=/nix/store/9kk1ji1gr4094f2w99w2y6ip2gnwjwn0-tzdata-2022g/share/zoneinfo"
ExecStart=/nix/store/lw0fml9skb0q4w2fqxmxasss413z3z61-source/hosts/router/upstream.sh
[root@router:/etc/systemd/system]# ls /nix/store/lw0fml9skb0q4w2fqxmxasss413z3z61-source/hosts/router/upstream.sh
ls: cannot access '/nix/store/lw0fml9skb0q4w2fqxmxasss413z3z61-source/hosts/router/upstream.sh': No such file or directory
my flake dir:
[nix-shell:~/workspace/nixos]$ tree
├── builder
├── common
│ ├── default.nix
│ └── users
│ └── default.nix
├── flake.lock
├── flake.nix
├── home
│ ├── custom.fish
│ ├── default.nix
│ └── neovim.nix
├── hosts
│ ├── gitea
│ │ ├── configuration.nix
│ │ └── default.nix
│ ├── homedog
│ │ ├── default.nix
│ │ └── hardware-configuration.nix
│ └── router
│ ├── default.nix
│ ├── upstream.nix
│ └── upstream.sh
├── keys
│ ├── builder_ed25519
│ └── builder_ed25519.pub
├── nixos.qcow2
└── ops
default.nix:
imports = [
./configuration.nix
./upstream.nix
