I’ve spent a lot of time searching what should I put in deps.
For example this is my build.nix:
with import <nixpkgs> {};
stdenv.mkDerivation {
name = "env";
nativeBuildInputs = [ pkg-config ];
buildInputs = [
autoreconfHook
xorg.libX11
xorg.libXi
xorg.libXext
libGLU
zlib
glibc.out
glibc.static
glew
pixman
cairo
pango
# workaround for npm dep compilation
# https://github.com/imagemin/optipng-bin/issues/108
shellHook = ''
LD=$CC$
and this is my run.nix:
{ pkgs ? import <nixpkgs> { } }:
with pkgs; mkShell {
name = "node-dev-shell";
# Attributes aren't interpolated by the shell, so $LD_LIBRARY_PATH ends up verbatim in your environment. You could remove it (if no users of this expr need it) or convert it to an export statement in shellHook, which runs as regular bash, including interpolation. https://stackoverflow.com/questions/69953573/nodejs-headless-gl-null-in-nixos/69953610?noredirect=1#comment123682825_69953610
# https://github.com/albertgoncalves/ranim/blob/e59ee646c155fefba69b6f3b9aaad0402d360c2e/shell.nix#L37
# test with `echo $LD_LIBRARY_PATH` after entering with nix-shell
APPEND_LIBRARY_PATH = "${libuuid.out}/lib:${lib.makeLibraryPath [ libGL ]}";
shellHook = ''
export LD_LIBRARY_PATH="$APPEND_LIBRARY_PATH:$LD_LIBRARY_PATH"
Is there an easier way? Maybe something like GitHub - lexleogryfon/de-generate: Dependency generator?
