How do I find out the list of supported valid arguments? Only cliion, and pycharm professional is listed as arguments. I couldn’t figure out the valid names from the source code.
The code must have changed for this error to occur. Previously the nix code did not evaluate, so the NixOS/home-manager module system would not be able to eval to give you this trace. It does now, so maybe you’re using a different entrypoint or just forgot you made a change.
Given your source hash changed, I’m betting on the latter.
Could you share some more of your code? I assumed you were using NixOS originally, this should be pretty easy to fix.
