I’m working on a package package that supports plugins. It expects them each as a zip file in the res subdirectory of a given path, but only one such ‘global’ path can be given.
Is there a good workflow for “merging” several output directories into one, and wrapping the original executable so I can pass the correct path?
In this scenario there are usually two derivations, the package itself and a wrapper derivation that joins the package with the plugins. The general pattern goes like this:
{ stdenv, runCommand... }:
# creates a new derivation that wraps the package binary and attaches to the plugins somehow.
withPlugins = plugins:
# some time it's possible to reference all the plugins individually
# if they all need to live in a folder then use symlinkJoin
let pluginsRef = symlinkJoin { name = "${pkg.name}-plugins"; paths = plugins; }; in
runCommand "${pkg.name}-with-plugins" {
buildInputs = [ makeWrapper ];
passthru.withPlugins = moarPlugins: withPlugins (moarPlugins ++ plugins);
makeWrapper ${package}/bin/whatever $out/bin/whatever \
--set PLUGIN_PATH ${pluginsRef}
pkg = stdenv.mkDerivation {
passthru = inherit withPlugins;
pkg
Like this it’s then possible to invoke thepackage.withPlugins with a list of plugins and get a new version of the package bound to those plugins.
I am also very interested in this approach. I am exploring ways to create a single derivation of R with a large set of R packages so that all the packages are “visible” to R as one package search path pointing to the root of the package “library” instead of each package accessible via its own path/derivation. Are there any examples of using this type of wrapper derivations in nixpkgs?
I am just starting to learn the Haskell ecosystem in nixpkgs. It feels like I need something similar to ghcWithPackages but for R so that I could create a single derivation which would include both R (preferably of a given version) and a given set of packages (leveraging nixpkgs.rPackages for dependencies, etc.) “bundled” together in one R package library. The amount of nix code supporting ghcWithPackages (https://github.com/NixOS/nixpkgs/blob/master/pkgs/development/haskell-modules/make-package-set.nix) looks overwhelming though.
The general approach is to make a derivation that builds an R package with a parameterised version of the compiler (see haskellPackages.mkDerivation). Then these are stitched together using symlinkJoin (in ghcWithPackages), then the compiler executable is wrapped to point the libdir to the correct place.
A simpler example of all this is the idrisPackages.with-packages function which does the same thing for idris packages.
