Hi,I am a beginner for nixos. And I am going to recompile a specify version of gcc,eg:gcc7.3。I overridden the gcc version and src attribute using overlay,like below:
self: pkgs:
with pkgs;
gcc7 = gcc7.cc.overrideAttrs(oldAttrs: rec {
version = "7.3.0";
src = [ ./gcc-7.3.0.tar.gz ];
let pkgs = import <nixpkgs> { overlays= [(import ./overlay1.nix)]; };
in pkgs.gcc7
the build error log show as follow:
/nix/store/29mhv9glx2zkjjrgyqv0skphkdmcwm9f-gcc-7.3.0.drv
building ‘/nix/store/29mhv9glx2zkjjrgyqv0skphkdmcwm9f-gcc-7.3.0.drv’…
$CPATH is /nix/store/5rrw5av331ddxnjvlb6ay9wjnfi30xl3-zlib-1.2.11-dev/include' $LIBRARY_PATH is
/nix/store/h3gdlnj633hagpq59zn7lhkfmfclcbb3-zlib-1.2.11/lib’
/nix/store/4k7n61apbmyw8wxh0914nyixpig7cia7-builder.sh: line 39: /nix/store/579l1jpqmwjfghmlh9mnj6ykx06q2g38-binutils-wrapper-2.35.1/nix-support/libc-ldflags-before: No such file or directory
unpacking sources
unpacking source archive /nix/store/i1kj8n31aan2bmidg5rwqasw42mbrzff-gcc-7.3.0.tar.gz
source root is gcc-7.3.0
setting SOURCE_DATE_EPOCH to timestamp 1516870173 of file gcc-7.3.0/MD5SUMS
patching sources
applying patch /nix/store/s6lavkpjqzihfs0vjfnnz7lizpsfmgnl-riscv-pthread-reentrant.patch
patching file gcc/config/riscv/linux.h
applying patch /nix/store/6m27y27zvzsjn1ir4y8mm9nc9xnh2sgx-riscv-no-relax.patch
patching file gcc/config/riscv/riscv.c
Hunk #1 succeeded at 3676 (offset -303 lines).
patching file gcc/config/riscv/riscv.opt
Hunk #1 succeeded at 102 (offset -4 lines).
patching file gcc/doc/invoke.texi
Hunk #1 succeeded at 976 (offset -66 lines).
Hunk #2 succeeded at 20976 (offset -2127 lines).
applying patch /nix/store/jgs1i4b4liw39b7i7mfp6z0bisz543ri-0001-Fix-build-for-glibc-2.31.patch
patching file libsanitizer/sanitizer_common/sanitizer_platform_limits_posix.cc
Hunk #1 succeeded at 1134 (offset -11 lines).
patching file libsanitizer/sanitizer_common/sanitizer_platform_limits_posix.h
applying patch /nix/store/pz03lhak99nzyyni72m14zsjzfjvqvr8-no-sys-dirs.patch
patching file gcc/cppdefault.c
patching file gcc/gcc.c
Hunk #1 succeeded at 1464 (offset 302 lines).
applying patch /nix/store/bqdcpm73hcngcsk8081ray23fznlah0h-libsanitizer-no-cyclades-9.patch
patching file libsanitizer/sanitizer_common/sanitizer_common_interceptors_ioctl.inc
Hunk #1 succeeded at 361 (offset -4 lines).
Hunk #1 FAILED at 157.
Hunk #2 succeeded at 443 (offset -23 lines).
Hunk #3 succeeded at 809 (offset -23 lines).
1 out of 3 hunks FAILED – saving rejects to file libsanitizer/sanitizer_common/sanitizer_platform_limits_posix.cc.rej
Hunk #1 succeeded at 987 (offset -53 lines).
Hunk #2 succeeded at 1331 (offset -53 lines).
builder for ‘/nix/store/29mhv9glx2zkjjrgyqv0skphkdmcwm9f-gcc-7.3.0.drv’ failed with exit code 1
error: build of ‘/nix/store/29mhv9glx2zkjjrgyqv0skphkdmcwm9f-gcc-7.3.0.drv’ failed
so how can I fix it? thanks!
update:
I resolve the problem by manually comment out the ustat.h in gcc-x.x.x/libsanitizer/sanitizer-common/sanitizer-platform-limits-posix.cc (line number 157 and 250). Because archlinux deprecated the ustat.h in glibc.
As far as I know so far,the nixpkgs provides multiple version of gcc,for each version,it patches gcc fed in patch options。If I want to support gcc version of each commit,what is the best adaptation solution?
