Currently, I am building derivations for some shell plugins that are not available in nixpkgs, e.g. goto. To isolate the result hermetically, I would like to either execute the script with a custom path that links the dependencies or to replace every program invocation by the absolute path to that program.
For standalone scripts, one could use wrapProgram
. But since the plugin is not executed in a subshell but sourced instead, wrapProgram
is not applicable in this case. Do you know any solutions to the ideas I mentioned above?
Looking at nixpkgs, e.g. the zsh-autosuggestions
plugin, I found that some shell plugins are not isolated at all. Is this intended?
