How to package Yarn v2 project?
Hi, I’m trying to package a project that uses Yarn v2 lockfiles. I do not really know anything about Node.js development, I simply want to use this project myself and thus want to package it. However, I cannot get this to work.
Attempting to use fetchYarnDeps does not work, as the project uses a v2 lockfile and this function seemingly only supports Yarn 1 lockfiles. Thus, I tried to follow [quote=“dxwil, post:1, topic:51104, full:true”]
I’m trying to create an offline yarn cache for a yarn v2 lock file manually (because v2 doesn’t support fetchYarnDeps).
I saw Cannot create an offline yarn cache, it's empty and tried to replicate their subderivation, however, it does not work. Running it simply results in an error reading RequestError: getaddrinfo EAI_AGAIN registry.yarnpkg.com, indicating a DNS failure. The only way I found to solve this is by disabling the build sandbox, but this is not ideal and I want to avoid this.
Furthermore, even disabling the sandbox still results in an empty and thus useless derivation. I suspect this is because the solution in the linked thread no longer works, attempting to use --cache-folder results in an error indicating that this command line option is deprecated and can no longer be used. Other methods of setting cacheFolder to $out do not seem to work either, confusingly.
Below is included my code so far. If there is a better way to use v2 yarn lockfiles I would like to hear it.
{ lib, config, pkgs, ... }:
let pkg = pkgs.stdenv.mkDerivation(finalAttrs: rec {
  pname = "actualbudget";
  version = "24.11.0";
  src = pkgs.fetchFromGitHub {
    owner = "actualbudget";
    repo = "actual-server";
    rev = "refs/tags/v${finalAttrs.version}";
    hash = "sha256-GwtJ42dBJXrOBIxwdrSvNeqQCl91m1XrtS3RBpEuZX0=";
  yarnOfflineCache = pkgs.stdenv.mkDerivation { inherit src;
  name = "actualbudget-${version}-offline-cache";
      yarn
      cacert # needed for git
      gitMinimal # needed to download git dependencies
      nodejs # needed for npm to download git dependencies
      python3
      jq
      moreutils
    ELECTRON_SKIP_BINARY_DOWNLOAD = "1";
    buildPhase = ''
      runHook preBuild
      export HOME=$(mktemp -d)
      yarn config set enableTelemetry 0
      yarn config set cacheFolder $out
      yarn
      runHook postBuild
    dontConfigure = true;
    dontInstall = true;
    dontFixup = true;
    unstable.yarnConfigHook # unstable is an overlay containing unstable nixpkgs
    unstable.yarnBuildHook
    nodejs
    npmHooks.npmInstallHook
  }); in
A viable option is to use GitHub - stephank/yarn-plugin-nixify: Yarn v3/v4 plugin to help with Nix packaging
A kind person on the nixpkgs issue tracker pointed me to this issue, which contains some workarounds to potentially make this work: fetchYarnDeps doesn't support v2 (YAML) lockfiles · Issue #254369 · NixOS/nixpkgs · GitHub
I have not tried this, as I’ve given up and resorted to just using the Docker image provided by the project I was trying to package, but linking here in case anyone else runs into this.
