I want to configure doom-emacs declaratively within my nix flake following ryan4yin’s nix-config (ref). I don’t understand exactly how he’s passing the doomemacs non-flake input to the emacs home-manager module. This is a simplified version of what I’ve tried so far…
flake.nix
darwin = {
url = "github:LnL7/nix-darwin/master";
doomemacs = {
url = "github:doomemacs/doomemacs";
flake = false;
home-manager.url = "github:nix-community/home-manager";
outputs =
{ self
, darwin
, doomemacs
, home-manager
, nixpkgs
} @inputs:
darwinConfigurations = {
macos = darwin.lib.darwinSystem {
system = "aarch64-darwin";
specialArgs = inputs;
modules = [
home-manager.darwinModules.home-manager
./darwin
darwin/default.nix
{ config, pkgs, ... }:
imports = [
./home-manager.nix
darwin/home-manager.nix
{ config, pkgs, lib, home-manager ... }@inputs:
user = "adam";
imports = [ ];
users.users.${user} = {
name = "${user}";
home = "/Users/${user}";
isHidden = false;
shell = pkgs.zsh;
# Enable home-manager
home-manager = {
useGlobalPkgs = true;
extraSpecialArgs = { inherit inputs; };
users.${user} = { pkgs, config, lib, ... }: {
imports = [
../modules/doom-emacs
home.stateVersion = "21.11";
modules/doom-emacs/default.nix
config,
lib,
pkgs,
doomemacs,
with lib; let
envExtra = ''
export PATH="${config.xdg.configHome}/emacs/bin:$PATH"
shellAliases = {
e = "emacsclient --create-frame"; # gui
et = "emacsclient --create-frame --tty"; # termimal
myEmacsPackagesFor = emacs: ((pkgs.emacsPackagesFor emacs).emacsWithPackages (epkgs: [
epkgs.vterm
options.modules.editors.emacs = {
enable = mkEnableOption "Emacs Editor";
config = (mkMerge [
home.packages = with pkgs; [
## Doom dependencies
git
ripgrep
gnutls # for TLS connectivity
fd # faster projectile indexing
imagemagick # for image-dired
programs.bash.bashrcExtra = envExtra;
programs.zsh.envExtra = envExtra;
home.shellAliases = shellAliases;
xdg.configFile."doom" = {
source = ./doom;
force = true;
home.activation.installDoomEmacs = lib.hm.dag.entryAfter ["writeBoundary"] ''
${pkgs.rsync}/bin/rsync -avz --chmod=D2755,F744 ${doomemacs}/ ${config.xdg.configHome}/emacs/
(mkIf pkgs.stdenv.isDarwin (
# macport adds some native features based on GNU Emacs 29
# https://bitbucket.org/mituharu/emacs-mac/src/master/README-mac
emacsPkg = myEmacsPackagesFor pkgs.emacs29;
home.packages = [emacsPkg];
launchd.enable = true;
launchd.agents.emacs = {
config = {
ProgramArguments = [
"${pkgs.bash}/bin/bash"
"-l"
"-c"
"${emacsPkg}/bin/emacs --fg-daemon"
StandardErrorPath = "${config.home.homeDirectory}/Library/Logs/emacs-daemon.stderr.log";
StandardOutPath = "${config.home.homeDirectory}/Library/Logs/emacs-daemon.stdout.log";
RunAtLoad = true;
KeepAlive = true;
And this is what I get when I nix build the flake.
$ nix --experimental-features 'nix-command flakes' build #darwinConfigurations.macos.system
Starting build...
error:
at /builtin/derivation.nix:9:12: (source not available)
… while evaluating derivation 'darwin-system-24.05.20240216.5863c27+darwin4.0e6857f'
whose name attribute is located at /nix/store/bg5fbkfa5x53clcjf4p5p92k1l3w8x38-source/pkgs/stdenv/generic/make-derivation.nix:353:7
… while evaluating attribute 'activationScript' of derivation 'darwin-system-24.05.20240216.5863c27+darwin4.0e6857f'
at /nix/store/zijb0iz5kl0argc40l2fqfai4s8mbj91-source/modules/system/default.nix:95:7:
94|
95| activationScript = cfg.activationScripts.script.text;
96| activationUserScript = cfg.activationScripts.userScript.text;
error: attribute 'doomemacs' missing
at /nix/store/bg5fbkfa5x53clcjf4p5p92k1l3w8x38-source/lib/modules.nix:508:28:
507| builtins.addErrorContext (context name)
508| (args.${name} or config._module.args.${name})
509| ) (lib.functionArgs f);
It seems the issue is that the doomemacs flake input isn’t available to my doom-emacs module. Any idea how I can fix this?
