Hi all, I am new to NixOS and have a grand plan to put a router in a VM in a VM.
For context I am using a NixOS VM on my proxmox server to practice and learn Nix and I am trying to use openwrt-imagebuilder and NixVirt flakes, and I am currently stuck on the first step of utilizing the openwrt-imagebuilder flake: https://github.com/astro/nix-openwrt-imagebuilder
The issue I am encountering is that when I run my nixos-rebuild switch command, it says I have to run in impure mode, as I have not provided pkgs to the openwrt-imagebuilder flake. When I put inherit pkgs in the config that is passed into the build command for that flake, I get an infinite recursion error for pkgs.here is the file:
{pkgs, nixvirt, inputs, ...}:
config = {
release = "24.10.4";
target = "x86";
variant = "64";
profile = "generic";
packages = [
"luci"
"luci-base"
"luci-mod-admin-full"
"luci-theme-bootstrap"
"luci-app-firewall"
"luci-app-opkg"
"luci-ssl"
"adblock"
"luci-app-adblock"
"kmod-tun"
"ca-certificates"
"ca-bundle"
"libustream-openssl"
"curl"
"wget-ssl"
"bash"
"htop"
"nano"
"coreutils"
"coreutils-base64"
"tcpdump-mini"
"bind-dig"
"ip-full"
disabledServices = [];
files = pkgs.runCommand "image-files" {} ''
mkdir -p $out/etc/uci-defaults
cat > $out/etc/uci-defaults/99-custom <<EOF
uci -q batch << EOI
set system.@system[0].hostname='nixrouter'
commit
EOI
EOF
openwrtImg = inputs.openwrt-imagebuilder.lib.build config;
in "${openwrtImg}"
Here is the error when I place inherit pkgs; in config above release:
warning: Git tree '/etc/nixos' is dirty
error:
… while calling the 'seq' builtin
at /nix/store/02hdlzb9xkjvpl4kdia3snvccdhmm893-source/lib/modules.nix:359:18:
358| options = checked options;
359| config = checked (removeAttrs config [ "_module" ]);
360| _module = checked (config._module);
at /nix/store/02hdlzb9xkjvpl4kdia3snvccdhmm893-source/lib/modules.nix:295:9:
294| checkUnmatched =
295| if config._module.check && config._module.freeformType == null && merged.unmatchedDefns != [ ] then
296| let
… while evaluating the module argument `pkgs' in "/nix/store/s6k9x1nn3gml03lsad23fpg6aj813j7b-source/network/openwrt.nix":
error: infinite recursion encountered
at /nix/store/02hdlzb9xkjvpl4kdia3snvccdhmm893-source/lib/modules.nix:652:66:
651| extraArgs = mapAttrs (
652| name: _: addErrorContext (context name) (args.${name} or config._module.args.${name})
653| ) (functionArgs f);
My goal is to run the build successfully in a “pure” fashion, I guess that means without the look up in openwrt-imagebuilder, which I believe happens when pkgs is not supplied directly.
I have tried pkgs = pkgs, inherit pkgs, and pkgs = inputs.nixpkgs.
Oh and here is my flake.nix:
description = "A simple NixOS flake";
nixpkgs.url = "github:NixOS/nixpkgs/nixos-25.05";
helix.url = "github:helix-editor/helix/master";
openwrt-imagebuilder = {
url = "github:astro/nix-openwrt-imagebuilder";
nixvirt = {
url = "https://flakehub.com/f/AshleyYakeley/NixVirt/*.tar.gz";
outputs = { self, nixpkgs, ... }@inputs: {
nixosConfigurations.nixos = nixpkgs.lib.nixosSystem {
specialArgs = {inherit inputs;};
modules = [
./configuration.nix
./network/openwrt.nix
