How to refer to current directory in shell.nix?
I’m developing a package that includes some Lua library files. Supposing my git repository is in /home/dan/src/example/, this means I need to set the environment variable LUA_PATH to /home/dan/src/example/lib/?.lua - and I’d like to do this in shell.nix
My first thought was to use ./. but that expands to a store path not to the “local” directory. I’d rather be able to use an absolute path here than just lib/?.lua which will fail as soon as I cd into a subdirectory
Any ideas?
Maybe it’s easier than I thought it was:
with import <nixpkgs> {};
(callPackage ./default.nix {}).overrideAttrs(o: rec {
  SWARM_BASE_PATH = "/tmp/services";
  PROJECT_ROOT = builtins.getEnv "PWD";
  LUA_PATH = "${PROJECT_ROOT}/lib/?.lua";
  nativeBuildInputs = [ pkgs.foreman ] ;
although it would be even better if I could find the path of the shell.nix file itself, then I can run nix-shell from other directories as well as .
  PROJECT_ROOT = builtins.toString ./.;
I was not expecting that to work, but … thank you very much!
Why does toString work there? For anyone skimming the thread:
FOO = builtins.toString ./.;
FOO2 = ./.;
nix-shell:~/src/swarm]$ echo $FOO
/home/dan/src/swarm
[nix-shell:~/src/swarm]$ echo $FOO2
/nix/store/3ll5lrn0cys4rfq0asvxz0jar2z24c21-swarm
Magic!
nix paths work like that:
If you reference something as a path and not a string it gets copied to the nix-store so it doesn’t change it output when you run it multiple times.
when you convert the current directory to a string you skip to copy to nix-store step and get the current directory as string.
:joy: I always end up looking for the same piece of information and almost always end here:
Just FYI, for those who put the devShell in their flake.nix, you will need to add --impure
$ nix develop --impure
to prevent the path from being copied to /nix/store.
OT but shouldn’t --impure rather be a default for develop then ?
Note that this isn’t true with flakes. builtins.toString ./. still makes a path to /nix/store for purity.
See bug: mkOutOfStoreSymlink still links inside nix store for flake and toString input · Issue #2660 · nix-community/home-manager · GitHub
I think so too, it’s a pitfall many of my nix-muggle colleagues run into when using dev shells. At least there should be a something one can set directly in flake.nix (or mkShell) to have it default to impure like:
# flake.nix
nixConfig.devShell.impure = true;  # or something
tried to do that with nix-direnv like so
use flake . --impure
but it still copies it from the nix store
Can you share the exact code?
here
I do not see you using toString anywhere there.
mb i repalced it with an harcoded path in the meantime, i have it commented out on the same line
